Looking for testers for UI
A while back I started coding a new UI for Urbackup. I originally tried to integrate it with the Windows server and eventually gave up and focused on Linux. I finally got some time to recode most of what I had started. Still finding and fixing issues, looking for input.
Hi, just a quick note about REPLICATION.
Using rsync and/or SSH is no good for server using btrfs because all of the space saving done by btrfs’s sub-volumes and snapshots will be lost as neither rsync or (various) SSH methods don’t understand btrfs snapshots etc.
You could try and backup only the top-level of each client’s folder/s which would give(at least) one copy for (exmple) offline backup.
I myself have been working on a shell script that will copy upto a depth of X for a given start date of Y for all clients in the server database. This script “knows” how to deal with btrfs parent/child relationships that are implemented by urbackup as sub-volumes and snapshots.
One thing ….that may help if you want to investigate btrfs replication is that the folders that are named after the client/virtual sub client….are NOT sub-volumes or snapshots ….it is the contents of these folders that contain the snapshots etc.
If you would like a copy of the script thus far (it’s incomplete) then let me know a way to send it to you.
Best of luck
David
Hey David, thanks for the info! TBH, replication is still on the radar, Im getting the issues worked out of everything then Ill focus on that, but Ill be making changes for sure.
