Linux GUI location?
Hi, installed the Linux client, how do i access the GUI? having major issues configurating it, we get it connected, it doesn’t backup then seems to loose the config when doing a status check… GUI would make this way easier to configure.
Did you install the command line only client? That one is … command line only and has no GUI.
Running ubuntu, is there a GUI version of the client?
Did you check the logs in the GUI of urbackup-server?
We use the NAS direct install for the server, if the log cant be seen in the web GUI we likely cant get at it.
The server GUI has a “Logs” section.
Will review over the next few days
UPDATE - No logs on the server, i know it connects i see it say YES in the server, no logs seems to say nothing happened, where would the logs be on the linux path tree?
Check the link I posted.
10.2 Logging
Will check this over the weekend
