This is for a Linux client v2.0.30.0.
I’m trying to setup several backup paths for a single client. I’m using the urbackupclientctl program to do this. It appears to reset already configured paths to the default options when adding new paths.
#urbackupclientctl add-backupdir -x -f -d / -n root
#rbackupclientctl list-backupdirs
PATH NAME FLAGS
/ root symlinks_optional,one_filesystem,share_hashes
So far looks good, right? I then add the second path:
#urbackupclientctl add-backupdir -x -f -d /boot -n boot
PATH NAME FLAGS
/ root follow_symlinks,symlinks_optional,share_hashes
/boot boot symlinks_optional,one_filesystem,share_hashes
It looks like it’s reset the options on the first path to the defaults. I haven’t let it run a backup like this, because I really don’t want it to span filesystems.
Which brings up a related question. In the documentation it is stated that flags are specified by appending “/” to the path. How does this work with Unix paths? /usr/local/one_filesystem doesn’t seem correct. Should it be \usr\local/one_filesystem?
