I installed the Linux client on a small X86 Mint (Ubuntu) system and a RaspberryPi-Zero running Pi-OS (both using block mode snapshots), rebooting after the install was complete. Both systems showed up as “online” in the server status window - but I can’t get them to run either a full file or image backup.
I had adjusted the file backup parameters for each Linux client on the server (changing the defaults which were set up for Windows to “/home/*” for a default directory) and then used the server status window’s “With Selected” option to queue full file and image backups. No backups are started or performed however and the next time I refresh the server status window there is no message about these processes still being queued. The logs display does not show that any backup was ever started on the Linux systems.
I saw in another post that someone had explictly set the included and excluded files on their Linux client, so I tried that too (using “/” for the included and then a short list of excluded directories), but still no backups were started for these clients.
I looked through the manual to see what the various command line options for the Linux client were, but since my browser won’t allow an automated search of the large document couldn’t find where this was actually discussed.
I am presuming that the Linux clients are actually running correctly, because they are showing up “online” in the Urbackup server status window. Puzzled that they are not running any backups. Any thoughts or suggestions would be greatly appreciated! Thank you!
