I have serverall questions related to some errors. I don’t know how to solve them properly. After a few research and intensive reading of the manual, I still don’t understand… so, here I am.
I managed to install Urbackup client on debian. The backup server is another debian, running OMV 3.0 with Urbackup server plugin.
At first the server and client couldn’t see each other ; I read in the manual it could come from the server being behind a switch (5. Client discovery in local area networks : … If you have NAT between server and client, you should use “Internet clients" )
Now the backup works fine and I can see the folder growing every day…
But every backup produces an error :
Server logs :
Errors
16/01/17 03:12
Creating snapshot of “/home” failed
Errors
16/01/17 03:12
Unable to create new logical volume with no extents
Errors
16/01/17 03:12
Creating snapshot of “home” failed.
Errors
16/01/17 03:12
Creating snapshot of “/portable/geogebra-portable/geogebra-portable” failed
Errors
16/01/17 03:12
Errors
16/01/17 03:12
Creating snapshot of “/tmp/.com.google.Chrome.TYfg58/SingletonSocket” failed
Errors
16/01/17 03:12
On the client I get :
sudo systemctl status urbackupclientbackend.service ● urbackupclientbackend.service - UrBackup Client backend Loaded: loaded (/lib/systemd/system/urbackupclientbackend.service; enabled) Active: active (running) since Mon 2017-01-16 02:05:04 CET; 21h ago Main PID: 17833 (urbackupclientb) CGroup: /system.slice/urbackupclientbackend.service └─17833 /usr/local/sbin/urbackupclientbackend --config /etc/default/urbackupclient --no-consoletime
Jan 16 03:11:49 Q urbackupclientbackend[17833]: ERROR: Unable to create new logical volume with no extents Jan 16 03:11:49 Q urbackupclientbackend[17833]: ERROR: Creating snapshot of "home" failed. Jan 16 03:11:49 Q urbackupclientbackend[17833]: ERROR: Creating snapshot of "/portable/geogebra-portable/geogebra-portable" failed Jan 16 03:11:49 Q urbackupclientbackend[17833]: ERROR: Unable to create new logical volume with no extents Jan 16 03:11:49 Q urbackupclientbackend[17833]: ERROR: Creating snapshot of "/tmp/.com.google.Chrome.TYfg58/SingletonSocket" failed Jan 16 03:11:49 Q urbackupclientbackend[17833]: ERROR: Unable to create new logical volume with no extents Jan 16 03:11:50 Q urbackupclientbackend[17833]: WARNING: Could not find shadowcopy for "home". The client was probably restarted. Jan 16 03:11:50 Q urbackupclientbackend[17833]: ERROR: Creating shadowcopy of "home" failed. Jan 16 03:12:29 Q urbackupclientbackend[17833]: ERROR: Error stating file "/home/quentin/.config/google-chrome/SingletonCookie" to get file tokens. Errno: 2 Jan 16 03:12:29 Q urbackupclientbackend[17833]: ERROR: Error stating file "/home/quentin/.config/google-chrome/SingletonLock" to get file tokens. Errno: 2
I guessed I managed to enable LVM snapshot altrough it seems to be impossible with my settings.
What did I do wrong, I don’t know.
I found this config file wich seems to be responsible :
/usr/local/etc/urbackup/snapshot.cfg
#This is a key=value config file for determining the scripts/programs to create snapshots
create_filesystem_snapshot=/usr/local/share/urbackup/lvm_create_filesystem_snapshot
remove_filesystem_snapshot=/usr/local/share/urbackup/lvm_remove_filesystem_snapshot
but…
$ sudo ls usr/local/share/urbackup/
ls: cannot access usr/local/share/urbackup/: No such file or directory
From my understanding, if I config the client from the server web control pannel, it should overwrite the client configuration… but it doesn’t seem to work completely that way.
For example, i set up the client as “internet”, set up a backup window : 1-7/3-4 and exclude some files… but I can’t prevent it to snapshot the drive.
Another thing I don’t understand : are those client settings applied ? What’s their point if I already set up the client configuration on the server ?
$ urbackupclientctl list
PATH NAME FLAGS
/home home follow_symlinks,symlinks_optional,share_hashes
Every thing I want is an up to date backup of my client /home (later I’ll add the other important drives).
What should i do ?
- delete the snapshot.cfg ?
- restart from scratch (nooooooooooooooo)
- something else…
Thanks for your future answers and for the wonderfull software ! ![]()
edit : I forgot to say but the client is headless. It is not what I wanted first, but I couldn’t make it work so…
edit2 : another info, I don’t know if it’s usefull :
/etc/rc.local
/usr/local/sbin/urbackupclientbackend -d
exit 0
