Linux client 2.4.11 urbackupclientctl can't connect to urbackupclientbackend
I’ve tried the tailored installer provided from the server and also the generic shell script installer from urbackup.org.
The urbackupclientbackend daemon is up and running:
root@asd:/usr/local/var/urbackup# systemctl status urbackupclientbackend
● urbackupclientbackend.service - UrBackup Client backend
     Loaded: loaded (/lib/systemd/system/urbackupclientbackend.service; enabled; vendor preset: enabled)
     Active: active (running) since Fri 2022-06-03 15:12:09 UTC; 10min ago
   Main PID: 46251 (urbackupclientb)
      Tasks: 12 (limit: 4698)
     Memory: 7.6M
        CPU: 1.670s
     CGroup: /system.slice/urbackupclientbackend.service
             └─46251 /usr/local/sbin/urbackupclientbackend --config /etc/default/urbackupclient --no-consoletime
Jun 03 15:12:09 asd systemd[1]: Started UrBackup Client backend.
it’s listening on port 35623:
root@asd:/usr/local/var/urbackup# ss -lnp | grep urb
tcp   LISTEN 0      4096                                      127.0.0.1:35623            0.0.0.0:*     users:(("urbackupclientb",pid=46251,fd=9))
tcp   LISTEN 0      4096                                          [::1]:35623               [::]:*     users:(("urbackupclientb",pid=46251,fd=10))
the backend is successfully connected to the server:
2022-05-29 00:15:29: Authed+capa for client 'asd' (encrypted-v2, token auth) - 1 spare connections
but urbackupclientctl cannot connect to the backend:
root@asd:/usr/local/var/urbackup# urbackupclientctl status
Error getting status
it was caused by the firewall.
How’d you fix the issue? I have the same problem
Like I said my problem was caused by the firewall, so make sure the client is allowed to reach the backend port on the lo interface
