I just successfully installed version 1.2.1. Here is the log for reference…
root@rex:/usr/local/var/urbackup/urbackup-client-1.2.1# make install
Making install in .
make[1]: Entering directory `/usr/local/var/urbackup/urbackup-client-1.2.1'
make[2]: Entering directory `/usr/local/var/urbackup/urbackup-client-1.2.1'
/usr/bin/install -c -D "./init.d_client" "/usr/local/etc/init.d/urbackup_client"
if ! test -e "/usr/local/etc/default/urbackup_client"; then /usr/bin/install -c -D "./defaults_client" "/usr/local/etc/default/urbackup_client"; fi
mkdir -p "/usr/local/var/urbackup"
mkdir -p "/usr/local/var/urbackup/data"
/bin/mkdir -p '/usr/local/sbin'
/usr/bin/install -c urbackup_client '/usr/local/sbin'
/usr/bin/install -c start_urbackup_client '/usr/local/sbin'
make[2]: Nothing to be done for `install-data-am'.
make[2]: Leaving directory `/usr/local/var/urbackup/urbackup-client-1.2.1'
make[1]: Leaving directory `/usr/local/var/urbackup/urbackup-client-1.2.1'
Making install in client
make[1]: Entering directory `/usr/local/var/urbackup/urbackup-client-1.2.1/client'
make[2]: Entering directory `/usr/local/var/urbackup/urbackup-client-1.2.1/client'
/bin/mkdir -p '/usr/local/bin'
/usr/bin/install -c urbackup_client_gui '/usr/local/bin'
mkdir -p "/usr/local/share/urbackup"
/usr/bin/install -c -m 644 ./data/*.png "/usr/local/share/urbackup/"
/usr/bin/install -c -m 644 ./data/*.xpm "/usr/local/share/urbackup/"
/usr/bin/install -c -m 644 ./data/info.txt "/usr/local/share/urbackup/"
/usr/bin/install -c -m 644 -D ./data/en/trans.mo "/usr/local/share/urbackup/en/trans.mo"
/usr/bin/install -c -m 644 -D ./data/fr/trans.mo "/usr/local/share/urbackup/fr/trans.mo"
make[2]: Leaving directory `/usr/local/var/urbackup/urbackup-client-1.2.1/client'
make[1]: Leaving directory `/usr/local/var/urbackup/urbackup-client-1.2.1/client'
Making install in cryptoplugin
make[1]: Entering directory `/usr/local/var/urbackup/urbackup-client-1.2.1/cryptoplugin'
make[2]: Entering directory `/usr/local/var/urbackup/urbackup-client-1.2.1/cryptoplugin'
/bin/mkdir -p '/usr/local/lib'
/bin/bash ./libtool --mode=install /usr/bin/install -c liburbackupclient_cryptoplugin.la '/usr/local/lib'
libtool: install: /usr/bin/install -c .libs/liburbackupclient_cryptoplugin.so.0.0.0 /usr/local/lib/liburbackupclient_cryptoplugin.so.0.0.0
libtool: install: (cd /usr/local/lib && { ln -s -f liburbackupclient_cryptoplugin.so.0.0.0 liburbackupclient_cryptoplugin.so.0 || { rm -f liburbackupclient_cryptoplugin.so.0 && ln -s liburbackupclient_cryptoplugin.so.0.0.0 liburbackupclient_cryptoplugin.so.0; }; })
libtool: install: (cd /usr/local/lib && { ln -s -f liburbackupclient_cryptoplugin.so.0.0.0 liburbackupclient_cryptoplugin.so || { rm -f liburbackupclient_cryptoplugin.so && ln -s liburbackupclient_cryptoplugin.so.0.0.0 liburbackupclient_cryptoplugin.so; }; })
libtool: install: /usr/bin/install -c .libs/liburbackupclient_cryptoplugin.lai /usr/local/lib/liburbackupclient_cryptoplugin.la
libtool: install: /usr/bin/install -c .libs/liburbackupclient_cryptoplugin.a /usr/local/lib/liburbackupclient_cryptoplugin.a
libtool: install: chmod 644 /usr/local/lib/liburbackupclient_cryptoplugin.a
libtool: install: ranlib /usr/local/lib/liburbackupclient_cryptoplugin.a
libtool: finish: PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/sbin" ldconfig -n /usr/local/lib
Libraries have been installed in:
/usr/local/lib
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the `LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the `LD_RUN_PATH' environment variable
during linking
- use the `-Wl,-rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
make[2]: Leaving directory `/usr/local/var/urbackup/urbackup-client-1.2.1/cryptoplugin'
make[1]: Leaving directory `/usr/local/var/urbackup/urbackup-client-1.2.1/cryptoplugin'
Making install in fileservplugin
make[1]: Entering directory `/usr/local/var/urbackup/urbackup-client-1.2.1/fileservplugin'
make[2]: Entering directory `/usr/local/var/urbackup/urbackup-client-1.2.1/fileservplugin'
/bin/bash ./libtool --mode=install /usr/bin/install -c liburbackupclient_fileservplugin.la '/usr/local/lib'
libtool: install: /usr/bin/install -c .libs/liburbackupclient_fileservplugin.so.0.0.0 /usr/local/lib/liburbackupclient_fileservplugin.so.0.0.0
libtool: install: (cd /usr/local/lib && { ln -s -f liburbackupclient_fileservplugin.so.0.0.0 liburbackupclient_fileservplugin.so.0 || { rm -f liburbackupclient_fileservplugin.so.0 && ln -s liburbackupclient_fileservplugin.so.0.0.0 liburbackupclient_fileservplugin.so.0; }; })
libtool: install: (cd /usr/local/lib && { ln -s -f liburbackupclient_fileservplugin.so.0.0.0 liburbackupclient_fileservplugin.so || { rm -f liburbackupclient_fileservplugin.so && ln -s liburbackupclient_fileservplugin.so.0.0.0 liburbackupclient_fileservplugin.so; }; })
libtool: install: /usr/bin/install -c .libs/liburbackupclient_fileservplugin.lai /usr/local/lib/liburbackupclient_fileservplugin.la
libtool: install: /usr/bin/install -c .libs/liburbackupclient_fileservplugin.a /usr/local/lib/liburbackupclient_fileservplugin.a
libtool: install: chmod 644 /usr/local/lib/liburbackupclient_fileservplugin.a
libtool: install: ranlib /usr/local/lib/liburbackupclient_fileservplugin.a
/usr/local/lib
during execution
during linking
make[2]: Leaving directory `/usr/local/var/urbackup/urbackup-client-1.2.1/fileservplugin'
make[1]: Leaving directory `/usr/local/var/urbackup/urbackup-client-1.2.1/fileservplugin'
Making install in fsimageplugin
make[1]: Entering directory `/usr/local/var/urbackup/urbackup-client-1.2.1/fsimageplugin'
make[2]: Entering directory `/usr/local/var/urbackup/urbackup-client-1.2.1/fsimageplugin'
/bin/bash ./libtool --mode=install /usr/bin/install -c liburbackupclient_fsimageplugin.la '/usr/local/lib'
libtool: install: /usr/bin/install -c .libs/liburbackupclient_fsimageplugin.so.0.0.0 /usr/local/lib/liburbackupclient_fsimageplugin.so.0.0.0
libtool: install: (cd /usr/local/lib && { ln -s -f liburbackupclient_fsimageplugin.so.0.0.0 liburbackupclient_fsimageplugin.so.0 || { rm -f liburbackupclient_fsimageplugin.so.0 && ln -s liburbackupclient_fsimageplugin.so.0.0.0 liburbackupclient_fsimageplugin.so.0; }; })
libtool: install: (cd /usr/local/lib && { ln -s -f liburbackupclient_fsimageplugin.so.0.0.0 liburbackupclient_fsimageplugin.so || { rm -f liburbackupclient_fsimageplugin.so && ln -s liburbackupclient_fsimageplugin.so.0.0.0 liburbackupclient_fsimageplugin.so; }; })
libtool: install: /usr/bin/install -c .libs/liburbackupclient_fsimageplugin.lai /usr/local/lib/liburbackupclient_fsimageplugin.la
libtool: install: /usr/bin/install -c .libs/liburbackupclient_fsimageplugin.a /usr/local/lib/liburbackupclient_fsimageplugin.a
libtool: install: chmod 644 /usr/local/lib/liburbackupclient_fsimageplugin.a
libtool: install: ranlib /usr/local/lib/liburbackupclient_fsimageplugin.a
/usr/local/lib
during execution
during linking
make[2]: Leaving directory `/usr/local/var/urbackup/urbackup-client-1.2.1/fsimageplugin'
make[1]: Leaving directory `/usr/local/var/urbackup/urbackup-client-1.2.1/fsimageplugin'
Making install in urbackupclient
make[1]: Entering directory `/usr/local/var/urbackup/urbackup-client-1.2.1/urbackupclient'
make[2]: Entering directory `/usr/local/var/urbackup/urbackup-client-1.2.1/urbackupclient'
/bin/bash ./libtool --mode=install /usr/bin/install -c liburbackupclient.la '/usr/local/lib'
libtool: install: /usr/bin/install -c .libs/liburbackupclient.so.0.0.0 /usr/local/lib/liburbackupclient.so.0.0.0
libtool: install: (cd /usr/local/lib && { ln -s -f liburbackupclient.so.0.0.0 liburbackupclient.so.0 || { rm -f liburbackupclient.so.0 && ln -s liburbackupclient.so.0.0.0 liburbackupclient.so.0; }; })
libtool: install: (cd /usr/local/lib && { ln -s -f liburbackupclient.so.0.0.0 liburbackupclient.so || { rm -f liburbackupclient.so && ln -s liburbackupclient.so.0.0.0 liburbackupclient.so; }; })
libtool: install: /usr/bin/install -c .libs/liburbackupclient.lai /usr/local/lib/liburbackupclient.la
libtool: install: /usr/bin/install -c .libs/liburbackupclient.a /usr/local/lib/liburbackupclient.a
libtool: install: chmod 644 /usr/local/lib/liburbackupclient.a
libtool: install: ranlib /usr/local/lib/liburbackupclient.a
/usr/local/lib
during execution
during linking
/usr/bin/install -c -m 644 -D "./backup_client.db" "/usr/local/var/urbackup/backup_client.db.template"
touch "/usr/local/var/urbackup/new.txt"
make[2]: Leaving directory `/usr/local/var/urbackup/urbackup-client-1.2.1/urbackupclient'
make[1]: Leaving directory `/usr/local/var/urbackup/urbackup-client-1.2.1/urbackupclient'
