Issues with installations of urbackup on centos 6
problems Urbackup client installation in centos 6
There are specific steps for the installation of urbackup on centos 6?
I download the source code, but I have problems in compilation.
I install wxwidgets 2.9.4
then, after the make and make install, I can not start the gui.
tells me the following error:
urbackup_client_gui: error while loading shared libraries: libwx_gtk2u_xrc-2.9.so.4: can not open shared object file: No such file or directory
Hi! Do you really need graphical frontend? If not, why not to use pre-build packages from repo?
https://build.opensuse.org/package/binaries/home:kot1grun/urbackup-client-nogui?repository=CentOS_6
you’re right, i dont need install a gui.
how I install this?
how i start the client?
thanks for the answer…
Did not see those yet. Added them to the download page. Thanks!
