Hello All,
I have just installed Urbackup 1.4.8 under Freenas 9.3 as jail .
The installation went with mounting freebsd jail and going trough compile ,all went well and and i could get into the portal and backed up my first agent .
I tried the next day to get into the web portal and its not responding and eventually connection failed, i tried to restart Urbackup server , after few sec i could get into it but few minutes later didn’t have access again.
Looking into logs “urbackup_srv.log” i see following attached below ,any idea what went wrong ?
Please advice
2015-06-06 07:54:12: WARNING: Shutting down (Signal 15)
2015-06-06 07:54:13: Exited Loop
2015-06-06 07:54:13: Deleting at…
2015-06-06 07:54:13: Deleting SelectThreads…
2015-06-06 07:54:13: Deleting lbs…
2015-06-06 07:54:13: Shutting down plugins…
2015-06-06 07:54:13: Deleting server…
2015-06-06 07:54:13: done.
2015-06-06 07:54:13: Loaded -url- plugin
2015-06-06 07:54:13: Loaded -cryptoplugin- plugin
2015-06-06 07:54:13: ERROR: DLL not found: Cannot open “/usr/local/lib/liburbackupserver_downloadplugin.so”
2015-06-06 07:54:13: ERROR: Loading /usr/local/lib/liburbackupserver_downloadplugin.so failed
2015-06-06 07:54:13: Loaded -fsimageplugin- plugin
2015-06-06 07:54:13: Starting HTTP-Server on port 55414
2015-06-06 07:54:13: HTTP: Server started up sucessfully!
2015-06-06 07:54:13: Creating files Indices…
2015-06-06 07:54:13: Started UrBackup…
2015-06-06 07:54:13: Removing temporary files…
2015-06-06 07:54:13: Recreating temporary folder…
2015-06-06 07:54:13: Backup destination cannot handle subvolumes and snapshots. Snapshots disabled.
2015-06-06 07:54:14: UrBackup Server start up complete.
2015-06-06 07:54:14: Creating SOCKET…
2015-06-06 07:54:14: done.
2015-06-06 07:54:14: Server started up sucessfully!
2015-06-06 07:54:14: Looking for old Sessions… 0 sessions
2015-06-06 07:54:44: New Backupclient: pc-02799
2015-06-06 07:55:14: Downloading version file…
2015-06-06 07:55:14: Downloading server version info…
2015-06-06 08:15:16: WARNING: Shutting down (Signal 15)
2015-06-06 08:15:17: Exited Loop
2015-06-06 08:15:17: Deleting at…
2015-06-06 08:15:17: Deleting SelectThreads…
2015-06-06 08:15:17: Deleting lbs…
2015-06-06 08:15:17: Shutting down plugins…
2015-06-06 08:15:35: done.
2015-06-06 08:15:35: Loaded -url- plugin
2015-06-06 08:15:35: Loaded -cryptoplugin- plugin
2015-06-06 08:15:35: ERROR: DLL not found: Cannot open “/usr/local/lib/liburbackupserver_downloadplugin.so”
2015-06-06 08:15:35: ERROR: Loading /usr/local/lib/liburbackupserver_downloadplugin.so failed
2015-06-06 08:15:35: Loaded -fsimageplugin- plugin
2015-06-06 08:15:35: Starting HTTP-Server on port 55414
2015-06-06 08:15:35: HTTP: Server started up sucessfully!
2015-06-06 08:15:35: Creating files Indices…
2015-06-06 08:15:35: Started UrBackup…
2015-06-06 08:15:35: Removing temporary files…
2015-06-06 08:15:35: Recreating temporary folder…
2015-06-06 08:15:35: Backup destination cannot handle subvolumes and snapshots. Snapshots disabled.
2015-06-06 08:15:35: UrBackup Server start up complete.
2015-06-06 08:15:35: Creating SOCKET…
2015-06-06 08:15:35: Server started up sucessfully!
2015-06-06 08:15:35: Looking for old Sessions… 0 sessions
2015-06-06 08:16:06: New Backupclient: pc-02799
2015-06-06 08:16:35: Downloading version file…
2015-06-06 08:16:35: Downloading server version info…
