Since update some installations to 2.5.x, I am experiencing a lot of problems with client settings and backup paths.
For example:
I have 2.5.19 cbt client in wich I defined some paths to backup (folders).
I didn´t make any change, and suddenly all my paths dissapears. The small icon that informs about current settings has changed from “lock” to “highway” and I can´t change it.
In server side, I didn´t make any change on this client, however it appears with the * in their name like I had changed something on it.
¿How can I reset it to default behavior?
¿Why dissapear backup paths in client?
I think this is a mess. Is there any documentation or something else about how this works??
I agree. What is the difference when in a group setting ‘Using setting from group’ (the lock) vs ‘Using setting configured here’ (the home)? Shouldn’t changing the GROUPS settings be both the same thing?
I think that, Instead of make supositions of how it works, it would be nice a little update to the documentation to explain it.
It´s only a suggestion to avoid missunderstandings.
