Hey there,
i got a really weird behaviour with the client pre_backup script. I excepted the client to wait for the script to execute and finish before starting the actual backup.
But it doens’t seem like it. I use the pre_backup script for turning on and mounting my backup drive. When everything is fine and the drive is readily mounted, it returns with 0. And it worked perfectly well with bacula.
But the UrBackup client seems to start the pre_backup script in parallel to starting the backup job. Which leads to some files being written in the mount point already when the drive is not mounted yet. The rest of the files are going to the mounted device. Of course this leads to a lot of weird failures in the end.
I didn’t expect this behaviour as it makes no sense for a pre_backup script, does it?
I have no idea how to fix this issue. Any help would be greatly appreciated!
Ah by the way, the script has a timeout in it to make sure the drive is ready and mounted before it returns. So that can’t be the issue.
