Is it possible to connect to specific server by just typing server identity key in server_idents.txt file?
Should work like this.
https://www.urbackup.org/faq.html
Thank you for your response.
The issue in solution you suggested is that “server_idents.txt” is a
combination of server identity key, public key and private key. Public and
private key is encoded at server side so it is difficult to generate a
correct server_ident.txt file at client side.
Can you please assist me how to generate correct server_idents.txt file in
below case:
- Server and client are freshly installed.
- Client and server has not connected, not even one time.
Regards,
Herdesh
In the documentation it says:
To authenticate an additional backup server you have to ask the server administrator for the server key (It is shown on the status page)
I thought I have seen it before in the GUI of the server, but now I cannot find it.
Sorry, no idea.
Have you tried the second option?
Another option is to use the same key and private/public key pair for all backup servers (The private/public key pair is present starting from UrBackup Server 1.4 as urbackup/server_ident.priv and urbackup/server_ident.pub).
if you go on to add a new client, server identity is shown there
Found it. Thanks.
@uroni: Could this be clarified in the FAQ?
Actually knowing the server key alone is not sufficient for forcing client server connection.
Second option requires copying server_idents.txt file to be present at client side, which in turn requires client to be paired with server. In my case i want to force client to get paired to specific server in first go.
There are many crude and manual way of doing it which i do not prefer because i want to deploy it on hundreds of computer.
Do you have any idea how to achieve it?
Please tell us what you want to achieve and why more clearly.
I think i dont understand your problematic.
Usecase:
Suppose, I have 2 PC A and B, i have installed UrBackup client as well as UrBackup server on both PC. In normal case UrBackup client may connect to any UrBackup server in same network, but i want my UrBackup client of PC A to connect to UrBackup server of PC A only not to that of PC B.
I hope you understand my problem now
Either
Dont install the key
Or
Disable backup for that client. For fist go, make default policy to not backup and use at least two client groups, server A backup, server B no backup.
