I just installed the CBT client and have been using it for a while.
I’m getting this “Did not track” message in the logs and I can’t figure out what it means.
Level Time Message Info 12/24/18 09:04 Starting scheduled incremental file backup… Info 12/24/18 09:04 Selected no components to backup Info 12/24/18 09:04 Did not track enough (volume resize?). Tracked 49152 should track 62530. CBT will disable itself once this area is written to and CBT will reengage itself. Info 12/24/18 09:04 Change block tracking active on volume C: Info 12/24/18 09:04 Scanning for changed hard links on volume of "C:"… Info 12/24/18 09:04 Indexing of "User Files" done. 792 filesystem lookups 73351 db lookups and 547 db updates Info 12/24/18 09:04 Did not track enough (volume resize?). Tracked 479232 should track 489298. CBT will disable itself once this area is written to and CBT will reengage itself. Info 12/24/18 09:04 Change block tracking active on volume D: Info 12/24/18 09:04 Scanning for changed hard links on volume of "D:"…
The client (Version 2.3.4-cbt beta) says:
Volumes with active change block tracking and no crash persistence (v2.13):
C:, D:
Volumes without change block tracking:
F:, X:
Is CBT working or not?
Any help will be appreciated.
…Andrew
