i am playing with urbackup and i found a problem which cant be solved by my selfs
I installed the client and configired everythink and in the debug log i see the following:
2016-11-10 22:42:08: Trying to connect to internet server “10.0.2.201” at port 55413
2016-11-10 22:42:08: Successfully connected.
2016-11-10 22:43:08: Error receiving challenge packet
2016-11-10 22:43:08: InternetClient: Had an auth error
On Serverside logs i dont see anythink special in the logs.
There are multiple ports that are used for UrBackup. You seem to only have the web interface port open. You also need to open the port for the internet backup service.
Also, the default internet backup port is 55415 and some ISPs may block high numbered ports. Mine does, for some reason. So you should change that port to something not blocked. In my case I found that port 8000 was fine, so I used that.
