Internet Restore Issue
Hello Everyone,
I am a new urbackup user. I have created a urbackup server on Windows Server 2022 machine and I have about 20 clients that I backup using Image only configuration and only over the internet, no local backups.
I am testing the debian based restore usb tool and I can connect to the server but I receive an error connecting to the service.
My attempts at enhancing debugging / logging to assist me in viewing exactly what is happening have failed.
Can anyone assist me with ideas on how to resolve this?
Thank you
At least you’re connecting to the Server. I can’t get past this step for some reason. :slightly_smiling_face:
I’m using the urbackup_restore_2.5.0.iso to boot into a VM to restore a Windows 10 Client-VM from the server. This is a Virtualbox VM.
I’m stuck at:
Then it says “Connected” - to what I don’t know, perhaps the server (see next SS), then it issues the following error:
So when I open a Terminal session and issue the ss -4 command, it confirms, based on what I see that it’s connected to the Server (Linux-Debian):
So if it’s supposedly connected, then why doesn’t it move onto the next step?
I’ve tried everything:
-swapping urbackup:// with the server IP
-tried using http & https:// with both the server IP and URL, both with and without the port 55414
I have no hair left on my head and my wife laughs at me! :rofl: :rofl: and then gives me the “L” sign.
I mean, this product just leaves you hanging!
I was going to create another thread, but I saw yours and figured I’d add to it.
I hope the developer or someone knowledgeable could help out here.
Just also thought of this.
I went to the backup server and displayed the active connections with ss -4 command and it definitely shows the client is connected:
server connections
Weird huh?! :thinking:
The manual is not much help either.
So I’m doing some more digging from some other posts while using the Linux client restore VM.
There is a directory /root that has some files that are dated from the restore attempt.
So:
-click on the bottom left goofy looking icon - select System Tools - LXTerminal
-this opens a CMD window (using Windows parlance :slightly_smiling_face:)
-type sudo ls -l /root
-you should see a list of all the files with the date you attempted your restore
-the ones I’m looking at are:
  • restore_client.log
  • restore_http.log, and
  • restore_mode.txt
-for each, you can issue the following command to scan for “errors, or warnings”
-type sudo grep -iE ‘error|warn’ /root/OneOfTheAboveFiles.xxx | more
-or, sudo cat /root/OneOfTheAboveFiles.xxx | more to see all of the entries a screen at a time
  • this should list every entry that has ‘error or warning’ in it, you can cancel the list by hitting ‘q’
The noted messages I see from restore_client.log (for my situation) are:
  • Error: Error loading clouddriveplugin
  • next weird warning: AWS-CLient: SDK was built without http implementation…can’t create http client instance
  • then, ClientService cmd: STATUS DETAIL#pw=88cc…
  • followed by, rc=0 hasError=true state=0, which fills the log up
  • then at the end there’s - shutting down, shutting down plugins, and finally deleting server
From restore_http.log:
  • Error connecting to client service -1
From restore_mode.txt:
  • Error setting file permissions to “urbackup/data/settings.cfg”
  • IRONICALLY, it successfully connects to the urbackup://myurbackupxxxxx:55415
  • Go Figure!!
  • then a whole bunch of, ClientService cmd: STATUS DETAIL#pw=88cc…
Then it just craps off leaving me stuck at the Configure Server Connections window.
Yup! There she is again with the big “L” sign on her forehead :angry:
Thought of the day:
If you’re gonna backup without a proven means to restore, you’re FoRkEd!!
Could you check if it works with the previous version ( https://hndl.urbackup.org/Restore/urbackup_restore_2.4.2.iso ) ?
I figured out my problem, and it was a real face palm moment.
I changed the setting for “max active” clients to 10 during my initial configuration of the server. Thinking it would help QOS, well I have 20 clients so once I got debug enabled for logs I could see that I was connecting but timing out due to no slots available for my restore. Changed the setting to 50 and all is good.
You are connecting and if you can view you log it will tell you what’s happening.
I am using a windows 2022 server instance, no VM’s as my virtual knowledge is subpar.
You need to change the line in args.txt file to “debug” for logs, replacing “warn”. This one change has allowed me to not only solve my internet restore problem, it has allowed to me to resolve every single error I was receiving. My backup server is damn near perfect now.
Cheers!
OK, downloaded the 2.4.2 iso and booted from it using my Virtualbox VM - btw. this iso doesn’t support EFI boot, fyi.
Here are the screenshots.
Failure to find backup server:
After providing server information to manually connect:
Checked my before and after ss -4 connections:
So the connection to the server, after checking ss -4 on the server, shows a connection, but cannot advance to next step to login to the server.
Other details from restore client boot:
Stuck!
Well, I see this has sat for nearly a month with no alternative being presented, maybe due to myself only having this issue.
So I guess the serious question really becomes:
If a restore cannot be accomplished because of funky connection issues, then what is the purpose of doing full image backups?
A backup (full image) is worthless without a proper ability/capability to restore.
In a funky connection scenario id drive across town to copy the image to a usb, drive back and restore via the usb. Or realistically scp it local or something. Just depends on how many people are breathing down my neck or how bad I needed that particular image at that particular moment in time.
