Hello
Server version is UrBackup 2.2.11
I edited the maintenance period to be like : 1-7/20-23:30,1-7/3-7,6-7/4-23:30 But before it was 1-7/3-4
And maintenance effectively starts at 3am, but it never ends until it’s fully done.
Is it possible to have the maintenance only done within the allocated time?
- Because it’s quite io expensive and the server is about unusable for other process during cleanup operations.
- Maybe put a banner in the web console or send an email if the allocated timeframe is too short and we should expand it.
- Maybe still allow it to finish the task it started, but not start a new one (in case there s a very long task, else it would never run)
Does it works properly if i split the maintenance like this : one part 20h-23h30 another 3am 7am?
Would the internal urbackup database would be done 2 times for example, can it even parse this?
As you can see, the process is still doing new maintenance at 8am, when my understanding is that it should have stopped at 7am
28/11/18 08:03 | DEBUG | Client with id=10 has 3 full file backups max=2 |
28/11/18 08:03 | INFO | Deleting full file backup ( id=5750, backuptime=2018-04-30 10:04:55, path=180430-1204 ) from client “ct03.zzz” ( id=10 ) … |
28/11/18 08:31 | INFO | Done. |
28/11/18 08:31 | DEBUG | Client with id=6 has 0 full file backups max=2 |
28/11/18 08:31 | DEBUG | Client with id=6 has 0 incremental file backups max=4 |
28/11/18 08:31 | DEBUG | Client with id=3 has 2 full file backups max=2 |
28/11/18 08:31 | DEBUG | Client with id=3 has 5 incremental file backups max=4 |
28/11/18 08:31 | INFO | Deleting incremental file backup ( id=8074, backuptime=2018-11-11 16:04:42, path=181111-1704 ) from client “ct02.zzz” ( id=3 ) … |
28/11/18 08:48 | INFO | Done. |
28/11/18 08:48 | DEBUG | Client with id=4 has 3 full file backups max=3 |
28/11/18 08:48 | DEBUG | Client with id=4 has 6 incremental file backups max=5 |
28/11/18 08:48 | INFO | Deleting incremental file backup ( id=8183, backuptime=2018-11-20 06:32:30, path=181120-0732 ) from client “ct01.zzz” ( id=4 ) … |
28/11/18 08:48 | DEBUG | Client with id=8 has 1 full file backups max=1 |
28/11/18 08:48 | DEBUG | Client with id=8 has 5 incremental file backups max=4 |
28/11/18 08:48 | INFO | Deleting incremental file backup ( id=8155, backuptime=2018-11-18 06:02:21, path=181118-0700 ) from client “ct01.zzz[gg]” ( id=8 ) … |
28/11/18 08:49 | INFO | Done. |
28/11/18 08:49 | DEBUG | Client with id=9 has 2 full file backups max=2 |
28/11/18 08:49 | DEBUG | Client with id=9 has 5 incremental file backups max=4 |
28/11/18 08:49 | INFO | Deleting incremental file backup ( id=8110, backuptime=2018-11-14 13:27:30, path=181114-1426 ) from client “ct01.zzz[jj]” ( id=9 ) … |
