Hello
I think i already reported that.
A maintenance can start for a client that is currently backuping.
i think that also new backups can start while a maintenance is running, for the same client.
And when both run at the same time, process can get stucks, ie urbackup process is not crashing and web ui is responding, but cleanup and backups are not progressing.
Its 10:48am
Maintenance logs :
| 28/11/18 08:03 | DEBUG | Client with id=10 has 3 full file backups max=2 |
| 28/11/18 08:03 | INFO | Deleting full file backup ( id=5750, backuptime=2018-04-30 10:04:55, path=180430-1204 ) from client “ct03.zzz” ( id=10 ) … |
| 28/11/18 08:31 | INFO | Done. |
| 28/11/18 08:31 | DEBUG | Client with id=6 has 0 full file backups max=2 |
| 28/11/18 08:31 | DEBUG | Client with id=6 has 0 incremental file backups max=4 |
| 28/11/18 08:31 | DEBUG | Client with id=3 has 2 full file backups max=2 |
| 28/11/18 08:31 | DEBUG | Client with id=3 has 5 incremental file backups max=4 |
| 28/11/18 08:31 | INFO | Deleting incremental file backup ( id=8074, backuptime=2018-11-11 16:04:42, path=181111-1704 ) from client “ct02.zzz” ( id=3 ) … |
| 28/11/18 08:48 | INFO | Done. |
| 28/11/18 08:48 | DEBUG | Client with id=4 has 3 full file backups max=3 |
| 28/11/18 08:48 | DEBUG | Client with id=4 has 6 incremental file backups max=5 |
| 28/11/18 08:48 | INFO | Deleting incremental file backup ( id=8183, backuptime=2018-11-20 06:32:30, path=181120-0732 ) from client “ct01.zzz” ( id=4 ) … |
| 28/11/18 08:48 | DEBUG | Client with id=8 has 1 full file backups max=1 |
| 28/11/18 08:48 | DEBUG | Client with id=8 has 5 incremental file backups max=4 |
| 28/11/18 08:48 | INFO | Deleting incremental file backup ( id=8155, backuptime=2018-11-18 06:02:21, path=181118-0700 ) from client “ct01.zzz[gg]” ( id=8 ) … |
| 28/11/18 08:49 | INFO | Done. |
| 28/11/18 08:49 | DEBUG | Client with id=9 has 2 full file backups max=2 |
| 28/11/18 08:49 | DEBUG | Client with id=9 has 5 incremental file backups max=4 |
| 28/11/18 08:49 | INFO | Deleting incremental file backup ( id=8110, backuptime=2018-11-14 13:27:30, path=181114-1426 ) from client “ct01.zzz[jj]” ( id=9 ) … |
Backup logs of “ct01.zzz[jj]” ( id=9 ):
| 28/11/18 08:52 | DEBUG | HT: Copying file: “/var/docker/data/urbackup-server/datas//ct01.zzz[jj]/181128-0703/someotherpath/classes.html” |
| 28/11/18 08:52 | DEBUG | HT: Copying file: “/var/docker/data/urbackup-server/datas//ct01.zzz[jj]/181128-0703/someotherpath/groups.html” |
| 28/11/18 08:52 | DEBUG | HT: Copying file: “/var/docker/data/urbackup-server/datas//ct01.zzz[jj]/181128-0703/someotherpath/index.html” |
| 28/11/18 08:52 | DEBUG | HT: Copying file: “/var/docker/data/urbackup-server/datas//ct01.zzz[jj]/181128-0703/someotherpath/main.html” |
| 28/11/18 08:52 | DEBUG | HT: Copying file: “/var/docker/data/urbackup-server/datas//ct01.zzz[jj]/181128-0703/someotherpath/methods-alphabetical.html” |
| 28/11/18 08:52 | DEBUG | HT: Copying file: “/var/docker/data/urbackup-server/datas//ct01.zzz[jj]/181128-0703/someotherpath/methods-not-run.html” |
| 28/11/18 08:52 | DEBUG | HT: Copying file: “/var/docker/data/urbackup-server/datas//ct01.zzz[jj]/181128-0703/someotherpath/methods.html” |
| 28/11/18 08:52 | DEBUG | HT: Copying file: “/var/docker/data/urbackup-server/datas//ct01.zzz[jj]/181128-0703/someotherpath/reporter-output.html” |
| 28/11/18 08:52 | DEBUG | HT: Copying file: “/var/docker/data/urbackup-server/datas//ct01.zzz[jj]/181128-0703/someotherpath/testng.xml.html” |
| 28/11/18 08:52 | DEBUG | HT: Copying file: “/var/docker/data/urbackup-server/datas//ct01.zzz[jj]/181128-0703/someotherpath/toc.html” |
| 28/11/18 08:52 | DEBUG | HT: Copying file: “/var/docker/data/urbackup-server/datas//ct01.zzz[jj]/181128-0703/somepath/junit/helpers/TestJavaTools.class” |
