Instructions to install Client on Linux won't work for me. Can anyone help?
Hi all,
The page: https://www.urbackup.org/download.html
Says that I must perform this:
Install with:
TF=`mktemp` && wget "https://hndl.urbackup.org/Client/2.2.6/UrBackup%20Client%20Linux%202.2.6.sh" -O $TF && sh $TF; rm $TF
I try that, it downloads and then I get this error:
Verifying archive integrity... All good.
Uncompressing UrBackup Client Installer for Linux  100%
Sorry, you must be super user to install UrBackup Client. Try again with sudo?
I try that with the following:
sudo TF=`mktemp` && wget "https://hndl.urbackup.org/Client/2.2.6/UrBackup%20Client%20Linux%202.2.6.sh" -O $TF && sh $TF; rm $TF
and receive this error:
usage: sudo -h | -K | -k | -V
usage: sudo -v [-AknS] [-g group] [-h host] [-p prompt] [-u user]
usage: sudo -l [-AknS] [-g group] [-h host] [-p prompt] [-U user] [-u user] [command]
usage: sudo [-AbEHknPS] [-r role] [-t type] [-C num] [-g group] [-h host] [-p prompt] [-T timeout] [-u user] [VAR=value] [-i|-s] [<command>]
usage: sudo -e [-AknS] [-r role] [-t type] [-C num] [-g group] [-h host] [-p prompt] [-T timeout] [-u user] file ...
rm: cannot remove '/tmp/tmp.8QjylD1kPH': No such file or directory
I’m on Ubuntu 18.04 if that makes a difference? Can anyone offer any advice as to what I need to do?
Thank you
Try executing this first:
sudo -i
You will get a privileged shell, from where you can use the line in the download instruction.
Same here. I manually split the command out. Run:
Then
sudo sh ./"Client Linux 2.2.6.sh"
