Hi everyone,
I’m trying to use the installercreator.urbackup.org site to create a custom installer for internet clients. I have tried with both my public IP and my DNS address in the server URL field. I have also tried http and https. I’m getting the same error each time:
Getting login information from server…
Post https://xxxxxxx.urbackup.app:55414/x?a=salt: dial tcp xxx.xxx.xxx.xxx:55414: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Any idea what I’m doing wrong? I’ve got the ports forwarded on my firewall correctly - I can manually create an Internet client and use that custom installer and it works and backs up and everything. I can also access the web portal externally.
Thanks in advance for the help!
