Hi all,
I have run into a couple of problems on installation of urbackup. I followed the 6 steps on the document “Install client on Debian or Ubuntu from sources”
First: I unpacked the tar file an went through the installation instructions without a problem. But when I ran the “urbackupclientbackend -v info” I got:
2019-03-24 16:26:34: ERROR: urbackupserver: Failed binding socket to port 35623. Another instance of this application may already be active and bound to this port.
2019-03-24 16:26:34: ERROR: Binding tcp socket to port 35621 failed. Another instance of this application may already be active and bound to this port.
2019-03-24 16:26:34: ERROR: FileServ exit with error code: 99<
Second: The insructions called for an /etc/rc.local file that doesn’t exist on Debian systems. I created a new file with requested addition but am not sure whether the “before the exit 0” refers to a pre-existing entry or is part of the added line. I assumed that I refered to a preexisting entry and add it as a second line. When I ran the urbackupclientgui I got the following error:
(urbackupclientgui:26119): Gtk-WARNING **: 17:12:57.347: Unable to locate theme engine in module_path: “adwaita”,
(urbackupclientgui:26119): Gtk-WARNING **: 17:12:57.352: Unable to locate theme engine in module_path: “adwaita”,
I have the adwaita-qt package installed
I’m a bit stuck at this point. Any help will be sincerely appreciated.
gary
