Installation fails via RPM / DNF on Fedora 43
I’ve been using urbackup server for a few years on my Fedora server box (currently running Fedora 43)
Following the steps documented here: UrBackup - Download UrBackup for Windows, GNU/Linux or FreeBSD
To Install package home:uroni / urbackup-server
Instructions are as below:
For Fedora 43 run the following as root:
dnf config-manager addrepo --from-repofile=https://download.opensuse.org/repositories/home:uroni/Fedora_43/home:uroni.repo
dnf install urbackup-server
The dnf config-manager completes successfully:
dnf config-manager addrepo --from-repofile=``https://download.opensuse.org/repositories/home:uroni/Fedora_43/home:uroni.repo
but attempting to install the package fails:
Updating and loading repositories:
UrBackup (Fedora_43)        100% |   4.2 KiB/s |   1.6 KiB |  00m00s
Repositories loaded.
Failed to resolve the transaction:
Problem: conflicting requests
package urbackup-server-2.5.35.0-1.1.aarch64 from home_uroni does not have a compatible architecture
nothing provides group(urbackup) needed by urbackup-server-2.5.35.0-1.1.aarch64 from home_uroni
nothing provides user(urbackup) needed by urbackup-server-2.5.35.0-1.1.aarch64 from home_uroni
nothing provides ld-linux-aarch64.so.1()(64bit) needed by urbackup-server-2.5.35.0-1.1.aarch64 from home_uroni
nothing provides ld-linux-aarch64.so.1(GLIBC_2.17)(64bit) needed by urbackup-server-2.5.35.0-1.1.aarch64 from home_uroni
nothing provides libm.so.6(GLIBC_2.17)(64bit) needed by urbackup-server-2.5.35.0-1.1.aarch64 from home_uroni
nothing provides group(urbackup) needed by urbackup-server-2.5.35.0-1.1.x86_64 from home_uroni
nothing provides user(urbackup) needed by urbackup-server-2.5.35.0-1.1.x86_64 from home_uroni
You can try to add to command line:
–skip-broken to skip uninstallable packages
it seems like packages from the wrong architecture are being selected by default? (my machine is x86_64 but aarch64 packages are being selected)
if I try to install x86_64 packages explicitly, I get another different error:
dnf install urbackup-server.x86_64
I do have a urbackup user and group, although I’m not sure if this was manually created (by me) in the past or as a result of a prior install.
id urbackup
uid=964(urbackup) gid=964(urbackup) groups=964(urbackup)
I’m going to try installing Fedora 42 or Fedora Rawhide packages and report back.
This seems very similar to an issue reported against a different project here: opensuse16 rpm packaging - nothing provides 'group(proxysql)' · Issue #5183 · sysown/proxysql · GitHub
The fix may be as simple as adding Provides: group(urbackup) to the .spec file here: File urbackup-server.spec of Package urbackup-server - openSUSE Build Service
I’m going to experiment with building this locally and report back
OpenSUSE build should also allow you to fork the project and edit the file in the browser and then it builds it for you
Ah, thanks @uroni
I’ll give this a try first
Adding the following to urbackup-server.spec fixes installation on Fedora 43
# Required to prevent "nothing provides group(urbackup) needed by urbackup-server" errors during install
# Required to prevent "nothing provides user(urbackup) needed by urbackup-server" errors during install
Provides: user(urbackup)
Confirmed via my branch of the openSUSE build service project: Revisions of urbackup-server - openSUSE Build Service
@uroni I submitted a request to have the change made upstream here: Request 1333643: Submit home:uroni/urbackup-server - openSUSE Build Service
@uroni any thoughts on the fix I posted above?
is there any additional process I should follow for working to get it tested / committed?
thanks!
The build service did not show the changes at the time. Now it seems to work. Merged. Thanks!
Excellent, thank you!
I can confirm that installing via the OpenSuse Build Service repos now works without issue on Fedora 43
Package        Arch                Version        Repository                                                Size
Installing:
 urbackup-server        x86_64              2.5.35.0-2.1        home_uroni                                            18.0 MiB
Installing dependencies:
 dhcpcd        x86_64              10.3.0-2.fc43        updates                                              496.8 KiB
 fuse-libs        x86_64              2.9.9-24.fc43        fedora                                               297.1 KiB
 hexedit        x86_64              1.6-9.fc43        fedora                                                77.9 KiB
 hivex-libs        x86_64              1.3.24-10.fc43        fedora                                                84.8 KiB
 libguestfs        x86_64              1:1.58.1-1.fc43        updates                                                3.9 MiB
 libguestfs-appliance        x86_64              1:1.58.1-1.fc43        updates                                                3.2 MiB
 libldm        x86_64              0.2.5-2.fc43        fedora                                               136.8 KiB
 perl-Class-Inspector        noarch              1.36-19.fc43        fedora                                                57.5 KiB
 perl-Exporter-Tiny        noarch              1.006002-9.fc43        fedora                                                88.3 KiB
 perl-List-MoreUtils-XS        x86_64              0.430-18.fc43        fedora                                               162.6 KiB
 perl-Sys-Guestfs        x86_64              1:1.58.1-1.fc43        updates                                                1.1 MiB
 perl-hivex        x86_64              1.3.24-10.fc43        fedora                                                94.2 KiB
 perl-libintl-perl        x86_64              1.35-3.fc43        fedora                                                 4.1 MiB
 supermin        x86_64              5.3.5-6.fc43        fedora                                                 2.1 MiB
 syslinux        x86_64              6.04-0.33.fc43        fedora                                                 1.0 MiB
 syslinux-extlinux        x86_64              6.04-0.33.fc43        fedora                                               206.2 KiB
 syslinux-extlinux-nonlinux        noarch              6.04-0.33.fc43        fedora                                               976.8 KiB
 syslinux-nonlinux        noarch              6.04-0.33.fc43        fedora                                                 1.8 MiB
 virt-win-reg        noarch              1.55.4-1.fc43        updates                                               47.9 KiB
 zerofree        x86_64              1.1.1-16.fc43        fedora                                                49.9 KiB
Installing weak dependencies:
 perl-File-ShareDir        noarch              1.118-14.fc43        fedora                                                56.2 KiB
 perl-I18N-Langinfo        x86_64              0.24-521.fc43        updates                                               34.7 KiB
 perl-List-MoreUtils        noarch              0.430-14.fc43        fedora                                               162.6 KiB
 perl-Params-Util        x86_64              1.102-19.fc43        fedora                                                58.5 KiB
Transaction Summary:
 Installing:        25 packages
Total size of inbound packages is 13 MiB. Need to download 13 MiB.
After this operation, 38 MiB extra will be used (install 38 MiB, remove 0 B).
Is this ok [y/N]: y
[ 1/25] fuse-libs-0:2.9.9-24.fc43.x86_64        100% | 468.7 KiB/s |  97.0 KiB |  00m00s
[ 2/25] virt-win-reg-0:1.55.4-1.fc43.noarch        100% | 146.9 KiB/s |  31.4 KiB |  00m00s
[ 3/25] perl-hivex-0:1.3.24-10.fc43.x86_64        100% |   1.0 MiB/s |  46.4 KiB |  00m00s
[ 4/25] hivex-libs-0:1.3.24-10.fc43.x86_64        100% |   1.0 MiB/s |  43.8 KiB |  00m00s
[ 5/25] perl-libintl-perl-0:1.35-3.fc43.x86_64        100% |   2.9 MiB/s | 813.7 KiB |  00m00s
[ 6/25] perl-Sys-Guestfs-1:1.58.1-1.fc43.x86_64        100% | 958.6 KiB/s | 285.7 KiB |  00m00s
[ 7/25] hexedit-0:1.6-9.fc43.x86_64        100% |   1.0 MiB/s |  42.7 KiB |  00m00s
[ 8/25] libguestfs-1:1.58.1-1.fc43.x86_64        100% |   4.5 MiB/s |   1.2 MiB |  00m00s
[ 9/25] supermin-0:5.3.5-6.fc43.x86_64        100% |   5.3 MiB/s | 701.2 KiB |  00m00s
[10/25] syslinux-0:6.04-0.33.fc43.x86_64        100% |  11.1 MiB/s | 568.6 KiB |  00m00s
[11/25] syslinux-extlinux-0:6.04-0.33.fc43.x86_64        100% |   3.5 MiB/s | 131.8 KiB |  00m00s
[12/25] zerofree-0:1.1.1-16.fc43.x86_64        100% | 811.0 KiB/s |  27.6 KiB |  00m00s
[13/25] syslinux-nonlinux-0:6.04-0.33.fc43.noarch        100% |  11.4 MiB/s | 597.5 KiB |  00m00s
[14/25] syslinux-extlinux-nonlinux-0:6.04-0.33.fc43.noarch        100% |   8.9 MiB/s | 393.9 KiB |  00m00s
[15/25] libguestfs-appliance-1:1.58.1-1.fc43.x86_64        100% |   5.8 MiB/s |   3.2 MiB |  00m01s
[16/25] libldm-0:0.2.5-2.fc43.x86_64        100% |   1.6 MiB/s |  57.8 KiB |  00m00s
[17/25] perl-File-ShareDir-0:1.118-14.fc43.noarch        100% | 899.3 KiB/s |  29.7 KiB |  00m00s
[18/25] perl-Class-Inspector-0:1.36-19.fc43.noarch        100% | 942.0 KiB/s |  30.1 KiB |  00m00s
[19/25] dhcpcd-0:10.3.0-2.fc43.x86_64        100% | 960.8 KiB/s | 239.2 KiB |  00m00s
[20/25] perl-I18N-Langinfo-0:0.24-521.fc43.x86_64        100% | 423.2 KiB/s |  25.0 KiB |  00m00s
[21/25] perl-List-MoreUtils-0:0.430-14.fc43.noarch        100% |   1.8 MiB/s |  61.7 KiB |  00m00s
[22/25] perl-Exporter-Tiny-0:1.006002-9.fc43.noarch        100% |   1.4 MiB/s |  50.9 KiB |  00m00s
[23/25] perl-List-MoreUtils-XS-0:0.430-18.fc43.x86_64        100% |   1.7 MiB/s |  61.7 KiB |  00m00s
[24/25] perl-Params-Util-0:1.102-19.fc43.x86_64        100% | 959.0 KiB/s |  32.6 KiB |  00m00s
[25/25] urbackup-server-0:2.5.35.0-2.1.x86_64        100% | 789.8 KiB/s |   4.3 MiB |  00m06s
[25/25] Total        100% |   2.1 MiB/s |  12.9 MiB |  00m06s
Running transaction
[ 1/27] Verify package files        100% | 531.0   B/s |  25.0   B |  00m00s
[ 2/27] Prepare transaction        100% | 155.0   B/s |  25.0   B |  00m00s
[ 3/27] Installing hivex-libs-0:1.3.24-10.fc43.x86_64        100% |   5.6 MiB/s |  86.2 KiB |  00m00s
[ 4/27] Installing fuse-libs-0:2.9.9-24.fc43.x86_64        100% |  36.5 MiB/s | 298.8 KiB |  00m00s
[ 5/27] Installing perl-hivex-0:1.3.24-10.fc43.x86_64        100% |   4.7 MiB/s |  96.6 KiB |  00m00s
[ 6/27] Installing syslinux-0:6.04-0.33.fc43.x86_64        100% |  45.4 MiB/s |   1.0 MiB |  00m00s
[ 7/27] Installing syslinux-nonlinux-0:6.04-0.33.fc43.noarch        100% | 127.9 MiB/s |   1.8 MiB |  00m00s
[ 8/27] Installing syslinux-extlinux-nonlinux-0:6.04-0.33.fc43.noarch        100% |  87.5 MiB/s | 985.2 KiB |  00m00s
[ 9/27] Installing syslinux-extlinux-0:6.04-0.33.fc43.x86_64        100% [==================] | 202.3 MiB/s | 207.1 KiB |  00m00s
>>> Running %triggerin scriptlet: filesystem-0:3.18-50.fc43.x86_64        [ 9/27] Installing syslinux-extlinux-0:6.04-0.33.fc43.x86_64        100% |   6.5 MiB/s | 207.1 KiB |  00m00s
[10/27] Installing perl-List-MoreUtils-XS-0:0.430-18.fc43.x86_64        100% |  14.7 MiB/s | 165.7 KiB |  00m00s
[11/27] Installing perl-Exporter-Tiny-0:1.006002-9.fc43.noarch        100% |   7.0 MiB/s |  92.7 KiB |  00m00s
[12/27] Installing perl-Class-Inspector-0:1.36-19.fc43.noarch        100% |   5.8 MiB/s |  59.3 KiB |  00m00s
[13/27] Installing libldm-0:0.2.5-2.fc43.x86_64        100% |   1.7 MiB/s | 138.6 KiB |  00m00s
[14/27] Installing dhcpcd-0:10.3.0-2.fc43.x86_64        100% [==================] |  32.7 MiB/s | 501.5 KiB |  00m00s
>>> Running %triggerin scriptlet: filesystem-0:3.18-50.fc43.x86_64        [14/27] Installing dhcpcd-0:10.3.0-2.fc43.x86_64        100% |   7.0 MiB/s | 501.5 KiB |  00m00s
[15/27] Installing zerofree-0:1.1.1-16.fc43.x86_64        100% [==================] |  16.8 MiB/s |  51.7 KiB |  00m00s
>>> Running %triggerin scriptlet: filesystem-0:3.18-50.fc43.x86_64        Symlinking /usr/sbin/sparsify -> /usr/bin/sparsify
[15/27] Installing zerofree-0:1.1.1-16.fc43.x86_64        100% |   1.6 MiB/s |  51.7 KiB |  00m00s
[16/27] Installing supermin-0:5.3.5-6.fc43.x86_64        100% |  93.4 MiB/s |   2.1 MiB |  00m00s
[17/27] Installing libguestfs-appliance-1:1.58.1-1.fc43.x86_64        100% | 291.0 MiB/s |   3.2 MiB |  00m00s
[18/27] Installing hexedit-0:1.6-9.fc43.x86_64        100% |   4.6 MiB/s |  79.3 KiB |  00m00s
[19/27] Installing libguestfs-1:1.58.1-1.fc43.x86_64        100% [==================] | 326.4 MiB/s |   3.9 MiB |  00m00s
>>> Running %triggerin scriptlet: filesystem-0:3.18-50.fc43.x86_64        [19/27] Installing libguestfs-1:1.58.1-1.fc43.x86_64        100% | 126.4 MiB/s |   3.9 MiB |  00m00s
[20/27] Installing perl-Sys-Guestfs-1:1.58.1-1.fc43.x86_64        100% | 105.7 MiB/s |   1.1 MiB |  00m00s
[21/27] Installing perl-libintl-perl-0:1.35-3.fc43.x86_64        100% | 147.5 MiB/s |   4.1 MiB |  00m00s
[22/27] Installing virt-win-reg-0:1.55.4-1.fc43.noarch        100% |   1.7 MiB/s |  48.9 KiB |  00m00s
[23/27] Installing urbackup-server-0:2.5.35.0-2.1.x86_64        100% | 209.5 MiB/s |  18.0 MiB |  00m00s
[24/27] Installing perl-File-ShareDir-0:1.118-14.fc43.noarch        100% |   5.8 MiB/s |  59.2 KiB |  00m00s
[25/27] Installing perl-List-MoreUtils-0:0.430-14.fc43.noarch        100% |  17.9 MiB/s | 165.0 KiB |  00m00s
[26/27] Installing perl-Params-Util-0:1.102-19.fc43.x86_64        100% |   6.0 MiB/s |  61.0 KiB |  00m00s
[27/27] Installing perl-I18N-Langinfo-0:0.24-521.fc43.x86_64        100% |  35.6 KiB/s |  36.2 KiB |  00m01s
Complete!
