Below /mnt/ there is a Cifs/smb share which sometimes the server goes offline, at that moment it is not possible to properly access that folder. I don’t want urbackup to backup it anyway, so I’ve added it to the exclude list:
/mnt/*;/mnt/;
and also set the backup-job to stay inside the filesystem.
Unfortunately what happens is:
Errors
23/10/19 18:44
Error while listing files in folder “/mnt”. User may not have permissions to access this folder. Errno is 0
Errors23/10/19 18:44
Indexing files failed, because of error
Constructing of filelist of “compname” failed: error - index error
Backup had an early error. Deleting partial backup.
So it seems to try to list directories below /mnt eventhough it is in the exclude list. And also to list the directory which is the entry point to another filesystem (ok, there I’m not 100% sure if it should do it or not)
