TESTED ON:
I have tested this on both a NAS drive and physical HDD in the server.
one difference i noticed is on the Physical HDD it creates symlinks
On the NAS drive it does not create a symlink
But both NAS and Physical end up with the same results described below.
ISSUE:
after the first Full File Backup has ran and the next few days as it continues to do incremental backups the file size does not go down
EXAMPLE:
I have a software folder that is 20gb large
each backup that occurs is 20gb large and no changes have occurred on the source
QUESTION:
why are the incremental backups still the same size as the original backup
The question is, if hard links are working correctly on the NAS. You could test this using the Command here: https://superuser.com/questions/255731/make-a-hard-link-without-extra-programs-in-windows-7
It will also write it into the log if it cannot create hard links. If it uses hard links you have to look at the overall used space, as most directory size tools count hard linked files more than once.
I’ll look further into the symlink issue. I recently changed something there.
The folder names are a date YYYYMMDD-HHMMSS. You can just sort that alphabetically and you get them in ascending or descending order. There should be no difference between fulls and incrementals, they behave the same once on disk. If hardlinks are not working it even creates copies for each backup…
