Windows Server 2016, UrBackup server version 2.4.12 (did not work with 2.3.something also), latest client.
Settings: https://ibb.co/fMpJYhF
Interval for both incremental and full backups are 1-7/0-24
Manual incremental image backups work ok.
Hi!
In permissions the option “Allow client-side changing of settings” enabled or disabled?
If enabled disable it and try again.
If enabled than: The settings configured on the client will overwrite the settings configured here. If you want to change this behaviour do not allow the client to change settings.
I enabled “Allow client-side changing of settings” only for the first week of deployment. Since then I have it on Disabled because I could set all possible backup scenarios from the server. Maybe the issue is that I had this setting enabled before.
Do these checks:
I did the steps above. Settings on the client side seem ok. Incremental backups are still not working on all machines except on my PC.
I then directly compared settings.cfg in Program Files on my machine and 3 others. On my machine these two keys exist but not on others:
internet_server_proxy=
internet_server_proxy_def=
This is the only difference I could find.
However we don’t use internet backup.
