One of the clients does not make a copy of the disk image. The icon changes from white to yellow but nothing happens. The file copy is done correctly - the connection to the server is established. I reinstalled the client and turned off the firewall but it doesn’t help. It’s a virtual machine but on another machine the disk image copy is made. Any idea?
Have you checked the logs on client and server?
Hi log with client on Windows:
2023-01-02 19:33:54: WARNING: Parent of directory with FRN 99642141755573066 (Name “016200000000034A4FFC7CCA”) with FRN 281474976710685 not found. Searching via MFT as fallback.
2023-01-02 19:33:54: WARNING: Parent not found. Was probably deleted.
2023-01-02 19:33:54: WARNING: SQLite: Safety level may not be changed inside a transaction in “PRAGMA synchronous=FULL” errorcode: 1
2023-01-02 19:33:54: ERROR: Error preparing Query [PRAGMA synchronous=FULL]: Safety level may not be changed inside a transaction
2023-01-02 19:33:54: WARNING: SQLite: Safety level may not be changed inside a transaction in “PRAGMA synchronous = 1” errorcode: 1
2023-01-02 19:33:54: ERROR: Error preparing Query [PRAGMA synchronous = 1]: Safety level may not be changed inside a transaction
Sorry for replaying to old thread but im getting the exact errors but for file backup. Not image. Trying to back up vhdx thats located on the C drive
I am also seeing a lot of:
2023-07-21 13:10:34: WARNING: SQLite: Safety level may not be changed inside a transaction in "PRAGMA synchronous=FULL" errorcode: 1
2023-07-21 13:10:34: ERROR: Error preparing Query [PRAGMA synchronous=FULL]: Safety level may not be changed inside a transaction
2023-07-21 13:10:34: WARNING: SQLite: Safety level may not be changed inside a transaction in "PRAGMA synchronous = 1" errorcode: 1
2023-07-21 13:10:34: ERROR: Error preparing Query [PRAGMA synchronous = 1]: Safety level may not be changed inside a transaction
2023-07-21 13:10:34: WARNING: Parent of directory with FRN 4222124650677575 (Name "000F0000000045476A1B42BE") with FRN 1688849860290203 not found. Searching via MFT as fallback.
2023-07-21 13:10:34: WARNING: Parent not found. Was probably deleted.
but can’t find anything regarding this errors in the forum.
Does anybody know what are these SQLite errors?
Client :
- Windows 10 64bit 22H2
- Urbackup Client: 2.5.21
any news on it ?
