Your software is great but im having some issues. After the baackup says 100% complete the process sits at this point for 20 mins + using 30 - 40% cpu. I assume that it is doing some sort of verfication / checksum. Is there a way to speed up this process or disable it ?
I’ve also observed this behavior on my servers.
In my case it is due to a verrryyyy slow NAS.
The actual backup is fast, but in the web interface it is stuck at 100% for a long time.
I investigated and discovered that urBackup was still copying files into the NFS mounted share.
Check your log file with debug enabled to be sure…
