I successfully build urbackupsrv on machine and it runs like a charm.
When I install the same package on a different machine, urbackupsrv stops with an error ‘Illegal instruction’
Screenshot:
[root@odin urbackup]# /usr/bin/urbackupsrv run --config /etc/default/urbackupsrv
2017-10-22 12:41:46: Starting HTTP-Server on port 55414
2017-10-22 12:41:46: HTTP: Server started up successfully!
2017-10-22 12:41:46: SQLite: recovered 4 frames from WAL file /var/urbackup/backup_server.db-wal code: 283
2017-10-22 12:41:46: SQLite: recovered 8 frames from WAL file /var/urbackup/backup_server_link_journal.db-wal code: 283
2017-10-22 12:41:46: Started UrBackup…
2017-10-22 12:41:46: Testing if backup destination can handle subvolumes and snapshots…
Backupfolder not set
2017-10-22 12:41:47: Backup destination cannot handle subvolumes and snapshots. Snapshots disabled.
2017-10-22 12:41:47: Testing if backup destination can handle filesystem transactions…
2017-10-22 12:41:47: Image mounting disabled: Backupfolder not set
2017-10-22 12:41:47: WARNING: Backupfolder “C:\urbackup” does not exist. Not running recovery.
2017-10-22 12:41:47: Binding to interface enp0s13 for broadcasting…
2017-10-22 12:41:47: Broadcasting on interface IP 192.168.12.2
2017-10-22 12:41:47: UrBackup Server start up complete.
2017-10-22 12:41:47: Server started up successfully!
2017-10-22 12:41:47: Looking for old Sessions… 0 sessions
Illegal instruction
In /var/log/urbackup.log:
Build was done on : Linux zeus 4.12.12-1-ARCH #1 SMP PREEMPT Sun Sep 10 10:03:08 CEST 2017 i686 GNU/Linux
Error was on : Linux odin 4.13.7-1-ARCH #1 SMP PREEMPT Tue Oct 17 15:16:10 CEST 2017 i686 GNU/Linux
When I try to build it on th errormachine the file urbackupsrv was not created
