HOWTO urbackup @ QNAP (NAS)
what i have:
→ QNAP TS-121
what we need:
  • putty → a terminal → every time you see “#” you need putty
  • winSCP → an “file-explorer”
What we will do:
1. installing packages for compiling
1a) optware IPKG
1b) installing necessary packages for compiling
1c) edit the Optware.sh
2. installing missing packages for urbackup
2a) creating temp and install directory
2b) installing missing packages for urbackup
2bb) crypto++
2bbb) libcurl & libcurl-dev
3. installing urbackup-server
3a) download the source-code and unzip
3b) we set the “install-dir” with prefix
3c) compiling (make)
3d) edit the MAKEFILE
3e) make install
3f) edit the “start_urbackup_server”
4. Testing
4a) starting urbackup-server
4b) test if it works
4c) config the “backup-dir”
5. Autostart urbackup-server at startup
5a) create an “autorun.sh”
5b) edit the “qpkg.conf”#
---------------------------------------------LET US BEGIN-------------------------------
1a) optware IPKG
→ go to the app-center on your qnap and install the optware IPKG
→ for compiling the source code for urbackup we need some packages
→ logon with putty on your nas and type the following:
# ipkg update
# ipkg install libidn getopt unzip optware-devel
Fix the $PATH in “/etc/profile”
→ you can edit the Optware.sh with winSCP → go to
and open the
Look for the section of code which mentions
Replace it so that this part of the file looks like:
# adding Ipkg apps into system path ...
/bin/cat /etc/profile | /bin/grep "PATH" | /bin/grep "/opt/bin" 1>>/dev/null 2>>/dev/null
# Bug fix for following: put IPKG first, per http://forum.qnap.com/viewtopic.php?f=124&t=15663
# was [ $? -ne 0 ] && /bin/echo "export PATH=$PATH":/opt/bin:/opt/sbin >> /etc/profile
[ $? -ne 0 ] && /bin/echo "export PATH=/opt/bin:/opt/sbin:\$PATH" >> /etc/profile
save the file.
reboot the QNAP NAS and check – in admin shell (putty) – the $PATH environment : variable “ /opt/bin” and “/opt/sbin” should come before “/bin” and “/usr/bin”. For instance:
 # echo $PATH
/opt/bin:/opt/sbin:/bin:/sbin:/usr/bin:/usr/sbin:/usr/bin/X11:/usr/local/sbin
→ in the temp dir i will download the necessary source-code for compiling
→ Because my Qnap (121) has not enough space at “system-dir” i will use my “own” install dir for urbackup
→ the temp and install dir are now FIX!!! if you want anothe location for the temp and install dir you have adapt every time where you find my temp and install dir @ your own
temp dir:
with winSCP go to
[quote=“”]/share/HDA_DATA/[/quote]
create a
install dir:
with winSCP got to
[quote=“”] /share/HDA_DATA/[/quote]
create
in urbackup dir create an install dir and an backup dir
it shuld look like this:
/share/HDA_DATA/
…temp
…urbackup
,install
,backups
→ for compiling the source-code of urbackup successful we need some package
→ the crypto++ package need do be compiled and installed
2bb) crypto++
with putty type the following:
# cd /share/HDA_DATA/temp
# mkdir cryptopp
# cd cryptopp
download the source-code for crypto++ → the make will take a while ←
# wget http://prdownloads.sourceforge.net/cryptopp/cryptopp562.zip
# unzip cryptopp562.zip
# rm -r cryptopp562.zip
# make -f GNUmakefile
# make libcryptopp.a libcryptopp.so
# make install
→ if there comes an error message, with cryptest.exe (not enough space) → thats no problem
→ now you can delete the cryptopp folder in your temp
# rm -r /share/HDA_DATA/temp/cryptopp
# ipkg update
# ipkg install libcurl
# ipkg install libcurl-dev automake
REBOOT the system now
# reboot
→ with putty go to the temp dir
download the source-code for urbackup
# wget http://sourceforge.net/projects/urbackup/files/Server/1.2.3/urbackup-server-1.2.3.tar.gz/download
# tar xzf urbackup-server-1.2.3.tar.gz
# rm urbackup-server-1.2.3.tar.gz
# cd urbackup-server-1.2.3.261/
----------------------PREFIX----------------
→ we use the prefix to install urbackup on a place we want
→ because at my qnap is not enough space @ the “system directory”
→ this will install urbackup @ /share/HDA_DATA/urbackup/install/
→ the following command will check your qnap if all dependings are installed
# ./configure --prefix /share/HDA_DATA/urbackup/install/
→ when there was[color=#FF0000] NO ERROR-MESSAGE [/color] then we can compile the source-code
→ this will take a very long time–> go for lunch or coffe
# make
→ we have to edit the make file, because the “adduser” command will not work
→ go with winSCP to
[quote=“”]/share/HDA_DATA/temp/urbackup-server-1.2.3.261/[/quote]
and edit the[quote=“”]MAKEFILE[/quote]
→ go to the buttom and search for the following line:
adduser urbackup --system --quiet --group --home "$(DESTDIR)$(localstatedir)/urbackup" || true
→ and comment it out with #, so that it look like this:
###adduser urbackup --system --quiet --group --home "$(DESTDIR)$(localstatedir)/urbackup" || true
3e) make install
→ now we can “install” urbackup @ QNAP
→ All files shoud be installe @ /share/HDA_DATA/urbackup/install/
# make install
→ go with winSCP to
[quote=“”] /share/HDA_DATA/urbackup/install/sbin/ [/quote]
→ edit the[quote=“”] “start_urbackup_server” [/quote]
search for:
 PREFIX=/usr
replace with:
PREFIX=/share/HDA_DATA/urbackup/install
search for:
DAEMON_DIR="/var"
replace with:
DAEMON_DIR="/share/HDA_DATA/urbackup/install/var"
SAVE FILE!!!
4. Testing
with putty go to the install dir
# cd /share/HDA_DATA/urbackup/install/sbin
# ./start_urbackup_server
—> open your browser and type:
→ now you should see the webAdminPagePage
→ under Settung you should set the location where urbackup-server should save the “BACKUPS”
→ i set: [quote=“”]/share/HDA_DATA/urbackup/backups/[/quote]
→ [color=#FF4040]REMEMBER to adapt these lines if you use another location of your “install path”[/color]
→ I make some [color=#008000]“variables” [/color]–> there you can place your “install path”
→ with winSCP go to:
[quote=“”]/share/HDA_DATA/urbackup/install/sbin[/quote]
→ create the file:
[quote=“”]autorun.sh[/quote]
→ enter the following line into the “autorun.sh” file
#!/bin/sh
[color=#008000]PIDFILE="/var/run/urbackup_srv.pid"
LOGFILE="/var/log/urbackup.log"
HTTP_PORT=55414
FASTCGI_PORT=55413
INSTALL_DIR="/share/HDA_DATA/urbackup/install"
LIB_DIR="$INSTALL_DIR/lib"[/color]
start()
## go to the /var dir --> this is neccessary if you start urbackup_srv
cd /share/HDA_DATA/urbackup/install/var
## start the urbackp_srv with plugins
  /share/HDA_DATA/urbackup/install/sbin/urbackup_srv --daemon --http_port $HTTP_PORT --logfile $LOGFILE --pidfile $PIDFILE --plugin $LIB_DIR/liburbackupserver_urlplugin.so --plugin $LIB_DIR/liburbackupserver_cryptoplugin.so --plugin $LIB_DIR/liburbackupserver_downloadplugin.so --plugin $LIB_DIR/liburbackupserver_fsimageplugin.so --plugin $LIB_DIR/liburbackupserver_httpserver.so --plugin $LIB_DIR/liburbackupserver.so --http_root $INSTALL_DIR/var/urbackup/www --workingdir $INSTALL_DIR/var --user urbackup --snapshot_helper $INSTALL_DIR/bin/urbackup_snapshot_helper
stop()
   #echo "Shutting down "
   kill `cat $PIDFILE`
   rm -f $PIDFILE
   sleep 5
# you do not need to edit this lines
case "$1" in
  	start)
        start
    stop)
        stop
    restart)
        # Restarting the Daemon
        $0 stop
        $0 start
    echo "Usage: $0 {start|stop|restart}"
    exit 1
esac
exit 0
make the [quote=“”]“autorun.sh”[/quote] executable → press[quote=“”] F9[/quote] and set the permission to [quote=“”]0755[/quote]
[u]
[/u]
→ with winSCP goto
[quote=“”]/etc/config/[/quote]
→ edit the[quote=“”] “qpkg.conf”[/quote]
→ the [color=#FF4000]SHELL[/color] and the [color=#FF4000]INSTALL_PATH[/color] are the important lines
→ at the end of the line enter these following lines!! [color=#FF4040]REMEMBER to adapt these lines if you use anothe location of your “install path”[/color]
[urbackup]
Name = urbackup
Version = 0.1
Author = escctrl
Date = 2013-20-08
Shell = /share/HDA_DATA/urbackup/install/sbin/autorun.sh
Install_Path = /share/HDA_DATA/urbackup/install/sbin
Enable = TRUE
→ now reboot your QNAP and urbackup server shuld be autostart
[size=28]–>FINISH<—[/size]
Hi. I have Qnap 439. I would like to install urbackup serwer on it. I started to go with your tutorial but i don’t have enaugh space for “make install” of the for crypto++.
cp: writing `/usr/lib/libcryptopp.so’: No space left on device
[/mnt/HDA_ROOT/temp/cryptopp] # df -h
Filesystem Size Used Avail Use% Mounted on
rootfs 140M 99M 42M 71% /
/dev/root 140M 99M 42M 71% /
tmpfs 64M 292K 64M 1% /tmp
/dev/sda4 310M 217M 94M 70% /mnt/ext
/dev/md9 510M 83M 428M 17% /mnt/HDA_ROOT
/dev/md0 916G 552M 915G 1% /share/MD0_DATA
tmpfs 32M 0 32M 0% /.eaccelerator.tmp
Is there a way around this? Please help me.
I’ve put the HOWTO unto the wiki and linked it from the download page: https://urbackup.atlassian.net/wiki/display/US/HOWTO+install+UrBackup+on+a+QNAP+NAS
Hi. I managed somehow with low space for installing cryptopp. But now i have error with “3c) compiling (make)”. When i write make command it runs for a while but next i got an error:
make all-recursive
make[1]: Entering directory /mnt/HDA_ROOT/temp/urbackup-server-1.2.3.261' Making all in . make[2]: Entering directory /mnt/HDA_ROOT/temp/urbackup-server-1.2.3.261’
g++ -pthread -DLINUX -g -O2 -o urbackup_srv AcceptThread.o Client.o Database.o Query.o SelectThread.o Server.o ServerLinux.o ServiceAcceptor.o ServiceWorker.o SessionMgr.o StreamPipe.o Template.o WorkerThread.o main.o md5.o stringtools.o fastcgi.o Mutex_lin.o LoadbalancerClient.o DBSettingsReader.o file_common.o file_fstream.o file_linux.o FileSettingsReader.o LookupService.o SettingsReader.o Table.o OutputStream.o ThreadPool.o MemoryPipe.o Condition_lin.o MemorySettingsReader.o sqlite3.o shell.o SQLiteFactory.o PipeThrottler.o mt19937ar.o -ldl
AcceptThread.o: In function __exchange_and_add': /share/MD0_DATA/.qpkg/Optware/bin/../lib/gcc/i686-unknown-linux-gnu/4.2.1/../../../../include/c++/4.2.1/ext/atomicity.h:51: undefined reference to __sync_fetch_and_add_4’
/share/MD0_DATA/.qpkg/Optware/bin/…/lib/gcc/i686-unknown-linux-gnu/4.2.1/…/…/…/…/include/c++/4.2.1/ext/atomicity.h:51: undefined reference to __sync_fetch_and_add_4' /share/MD0_DATA/.qpkg/Optware/bin/../lib/gcc/i686-unknown-linux-gnu/4.2.1/../../../../include/c++/4.2.1/ext/atomicity.h:51: undefined reference to __sync_fetch_and_add_4’
AcceptThread.o:/share/MD0_DATA/.qpkg/Optware/bin/…/lib/gcc/i686-unknown-linux-gnu/4.2.1/…/…/…/…/include/c++/4.2.1/bits/basic_string.h:288: more undefined references to __sync_fetch_and_add_4' follow collect2: ld returned 1 exit status make[2]: *** [urbackup_srv] Error 1 make[2]: Leaving directory /mnt/HDA_ROOT/temp/urbackup-server-1.2.3.261’
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/mnt/HDA_ROOT/temp/urbackup-server-1.2.3.261’
make: *** [all] Error 2
Please, please help me with this I’m no Linux expert and i don’t know what to do with it.
Ok. i made some proggress. Now i only have:
[/share/MD0_DATA/temp/urbackup-server-1.2.3.261] # make
make all-recursive
make[1]: Entering directory /share/MD0_DATA/temp/urbackup-server-1.2.3.261' Making all in . make[2]: Entering directory /share/MD0_DATA/temp/urbackup-server-1.2.3.261’
g++ -m32 -pthread -DLINUX -O2 -march=i686 -o urbackup_srv AcceptThread.o Client.o Database.o Query.o SelectThread.o Server.o ServerLinux.o ServiceAcceptor.o ServiceWorker.o SessionMgr.o StreamPipe.o Template.o WorkerThread.o main.o md5.o stringtools.o fastcgi.o Mutex_lin.o LoadbalancerClient.o DBSettingsReader.o file_common.o file_fstream.o file_linux.o FileSettingsReader.o LookupService.o SettingsReader.o Table.o OutputStream.o ThreadPool.o MemoryPipe.o Condition_lin.o MemorySettingsReader.o sqlite3.o shell.o SQLiteFactory.o PipeThrottler.o mt19937ar.o -ldl
fastcgi.o: In function __gnu_cxx::__exchange_and_add(int volatile*, int)': fastcgi.cpp:(.text+0x5c0): undefined reference to __sync_fetch_and_add_4’
make[2]: Leaving directory /share/MD0_DATA/temp/urbackup-server-1.2.3.261' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory /share/MD0_DATA/temp/urbackup-server-1.2.3.261’
Please help me with this fastcgi.cpp error. Am i missing something?
i think you first tried to install @ system dir and then to local drive
please use the following drive:
/share/MD0_DATA/urbackup/install
and repeate the howto again
i also found maybe a solution for you. at the point with ./configure use the following code:
./configure --prefix /share/MD0_DATA/urbackup/install/ CC='gcc -march=i686' CXX='g++ -march=i686'
i hope this will help you
esc-ctrl
Hi.
Firstly i would like to thank you for your Tutorial and for your Help. I managed to properly compile and run Urbackup server on Qnap TS-439 Pro II+. I’ll describe what i had to change (comparing to your tutorial) to make the task successful.
I had to change the code to replace (shown bellow) because “# echo $PATH” didn’t want to change.
adding Ipkg apps into system path …
/bin/cat /etc/profile | /bin/grep “PATH” | /bin/grep “/opt/bin” 1>>/dev/null 2>>/dev/null
[ $? -ne 0 ] && /bin/echo “export PATH=/opt/bin:/opt/sbin:$PATH” >> /etc/profile
Becouse i have 2 disk’s i raid mode so my path for temp and install dir looks like this:
/share/MD0_DATA/
…temp
…urbackup
,install
,backups
2bb) crypto++
In my Qnap ther’s to little space on root drive to properly install crypto++. Thers not enaugh space for libcryptopp.a libcryptopp.so files, not mentionig the .exe file. So her’s proper installation of crypto++:
make -d
make install PREFIX=/share/MD0_DATA/.qpkg/Optware
ln -s /share/MD0_DATA/.qpkg/Optware/include/cryptopp /usr/include/cryptopp
ln -s /share/MD0_DATA/.qpkg/Optware/lib/libcryptopp.a /share/MD0_DATA/.qpkg/Optware/include/cryptopp/
When compaling urbackup (rinning make command), i had error:
Compile worked with prefix just like you wrote in your reply:
./configure --prefix /share/MD0_DATA/urbackup/install/ CC=‘gcc -march=i686’ CXX=‘g++ -march=i686’
After setting the above prefix, i had an error with libstdc++.la. This helped:
mkdir -p /home/slug/optware/ts509/toolchain/i686-unknown-linux-gnu/i686-unknown-linux-gnu/lib/
ln -s /share/MD0_DATA/.qpkg/Optware/lib/libstdc++.la /home/slug/optware/ts509/toolchain/i686-unknown-linux-gnu/i686-unknown-linux-gnu/lib
It’s not exactly true that adduser command does not work on Qnap. It works but you have to use parameters in different way, but it’s better to remove it anyway. When you remove adduser command the chown urbackup:urbackup “$(DESTDIR)$(localstatedir)/urbackup” command gives an error: urbackup user does not exist. So I had to set the user on existing admin account (simplest way):
chown admin:administrators “$(DESTDIR)$(localstatedir)/urbackup”
After those changes i was able to properly compile and install urbackup-server-1.2.3.261 properly on my TS-439 Pro II+.
Then i tried to install urbackup-server-1.2.4.304, and here’s probably question for uroni. When running make install command it gave me an error that liburbackupserver_cryptoplugin.lai file does not exist. That’s correct because after compiling in cryptoplugin folder there’s only liburbackupserver_cryptoplugin.la file. I changed the file extension to .lai and the make install command worked OK without any errors. So now I have working urbackup-server-1.2.4.304 on my TS-439 Pro II+ with latest Qnap firmware (QTS 4.0.2). I tried to install urbackup-server-1.3.0.0 version from WIP folder, but this does not want to compile at all. Gives me errors when running make command. Something changed?
That’s all. Maybe my work will help someone.
Following the instructions provided by @escctrl and @bondzo here (thank you!), compilation of 1.4.4 tarball on a QNAP TS-659 FW 4.1.1 fails with the error " ‘execvpe’ was not declared in this scope".
[/share/MD0_DATA/.tmp/urbackup-server-1.4.4] # ./configure --prefix /opt/urbackup/ CC='gcc -march=i686' CXX='g++ -march=i686'
…All goes well…
[/share/MD0_DATA/.tmp/urbackup-server-1.4.4] # mkdir -p /home/slug/optware/ts509/toolchain/i686-unknown-linux-gnu/i686-unknown-linux-gnu/lib/
[/share/MD0_DATA/.tmp/urbackup-server-1.4.4] # ln -s /share/MD0_DATA/.qpkg/Optware/lib/libstdc++.la
So far so good…
[/share/MD0_DATA/.tmp/urbackup-server-1.4.4] # make
main.cpp: In function 'int exec_wait(const std::string&, ...)':
main.cpp:111: error: 'execvpe' was not declared in this scope
make[3]: *** [main.o] Error 1
make[3]: Leaving directory `/share/MD0_DATA/.tmp/urbackup-server-1.4.4/snapshot_helper'
Any ideas anyone?
Will be fixed with the next version. Meanwhile you can remove the offending line ( line 111 in snapshot_helper/main.cpp) to fix the problem. The functionality is only relevant on the btrfs filesystem.
Deleted lines 111 and 112 and that did the trick - cheers!
Do you think if it possible to integrate urbackup as an app, it will be an overkill app for all Qnap owners
I’ve Done Every Steps Of This Guide But I’ve Problems Installing It In QNAP TS-112P
When I Do The make Command On Point 3c I Recieve A Series Of Errors…
[/share/HDA_DATA/temp/urbackup-server-1.2.4.304] # make
    make  all-recursive
    make[1]: Entering directory `/share/HDA_DATA/temp/urbackup-server-1.2.4.304'
    Making all in .
    make[2]: Entering directory `/share/HDA_DATA/temp/urbackup-server-1.2.4.304'
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT AcceptThread.o -MD -MP -MF .deps/AcceptThread.Tpo -c -o AcceptThread.o AcceptThread.cpp
    In file included from AcceptThread.h:3,
                     from AcceptThread.cpp:21:
    socket_header.h:22:7: warning: no newline at end of file
    In file included from AcceptThread.h:4,
    types.h:2:27: warning: no newline at end of file
    In file included from libfastcgi/../OutputStream.h:1,
                     from libfastcgi/fastcgi.hpp:26,
                     from AcceptThread.h:5,
    libfastcgi/../Interface/OutputStream.h:13:3: warning: no newline at end of file
    In file included from libfastcgi/fastcgi.hpp:26,
    libfastcgi/../OutputStream.h:12:3: warning: no newline at end of file
    In file included from Server.h:13,
                     from AcceptThread.cpp:22:
    Interface/Action.h:22:19: warning: no newline at end of file
    In file included from SelectThread.h:5,
                     from AcceptThread.cpp:24:
    Interface/Mutex.h:32:18: warning: no newline at end of file
    In file included from Interface/Condition.h:4,
                     from SelectThread.h:6,
    In file included from SelectThread.h:6,
    Interface/Condition.h:16:22: warning: no newline at end of file
    In file included from SelectThread.h:9,
    In file included from AcceptThread.cpp:24:
    SelectThread.h:44:24: warning: no newline at end of file
    In file included from Client.h:1,
                     from AcceptThread.cpp:25:
    mv -f .deps/AcceptThread.Tpo .deps/AcceptThread.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT Client.o -MD -MP -MF .deps/Client.Tpo -c -o Client.o Client.cpp
                     from Client.cpp:21:
    In file included from Client.h:2,
                     from Client.cpp:21:
                     from Client.cpp:22:
                     from Client.cpp:23:
                     from Client.cpp:23:
                     from Client.cpp:23:
                     from Client.cpp:23:
    mv -f .deps/Client.Tpo .deps/Client.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT Database.o -MD -MP -MF .deps/Database.Tpo -c -o Database.o Database.cpp
    In file included from Database.cpp:25:
    Interface/File.h:30:17: warning: no newline at end of file
                     from Database.cpp:27:
    In file included from Database.cpp:41:
    sqlite/shell.h:39:61: warning: no newline at end of file
    In file included from Database.h:4,
                     from Database.cpp:43:
    Interface/DatabaseInt.h:12:7: warning: no newline at end of file
    In file included from Database.h:6,
                     from Database.h:7,
    In file included from Database.h:7,
    Database.cpp:524:7: warning: no newline at end of file
    mv -f .deps/Database.Tpo .deps/Database.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT Query.o -MD -MP -MF .deps/Query.Tpo -c -o Query.o Query.cpp
                     from Query.cpp:24:
                     from Query.cpp:35:
                     from Query.cpp:35:
                     from Database.h:7,
                     from Query.cpp:35:
                     from Query.cpp:35:
    Query.cpp:448:7: warning: no newline at end of file
    mv -f .deps/Query.Tpo .deps/Query.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT SelectThread.o -MD -MP -MF .deps/SelectThread.Tpo -c -o SelectThread.o SelectThread.cpp
                     from SelectThread.cpp:24:
    In file included from SelectThread.cpp:24:
                     from SelectThread.cpp:25:
    In file included from WorkerThread.h:4,
                     from SelectThread.cpp:26:
                     from SelectThread.cpp:27:
    mv -f .deps/SelectThread.Tpo .deps/SelectThread.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT Server.o -MD -MP -MF .deps/Server.Tpo -c -o Server.o Server.cpp
                     from Server.cpp:31:
                     from Server.cpp:31:
    In file included from Interface/DatabaseFactory.h:5,
                     from Server.cpp:35:
    In file included from Server.cpp:35:
    Interface/DatabaseFactory.h:13:28: warning: no newline at end of file
                     from Server.cpp:37:
    In file included from Template.h:5,
                     from Server.cpp:38:
    Interface/Template.h:22:21: warning: no newline at end of file
    In file included from Template.h:6,
                     from Server.cpp:38:
    Interface/Table.h:18:18: warning: no newline at end of file
    In file included from Interface/SessionMgr.h:6,
                     from SessionMgr.h:4,
                     from Server.cpp:41:
    Interface/User.h:38:17: warning: no newline at end of file
    In file included from SessionMgr.h:4,
                     from Server.cpp:41:
    Interface/SessionMgr.h:19:23: warning: no newline at end of file
    In file included from SessionMgr.h:5,
                     from Server.cpp:41:
                     from SessionMgr.h:6,
                     from Server.cpp:41:
    In file included from SessionMgr.h:6,
                     from Server.cpp:41:
    In file included from Server.cpp:42:
    md5.h:118:15: warning: no newline at end of file
    In file included from ServiceAcceptor.h:3,
                     from Server.cpp:43:
    In file included from LookupService.h:1,
                     from Server.cpp:44:
    In file included from Server.cpp:44:
    LookupService.h:4:57: warning: no newline at end of file
    In file included from SettingsReader.h:4,
                     from FileSettingsReader.h:4,
                     from Server.cpp:45:
    Interface/SettingsReader.h:24:36: warning: no newline at end of file
    In file included from StreamPipe.h:2,
                     from Server.cpp:47:
    In file included from ThreadPool.h:6,
                     from Server.cpp:48:
    Interface/ThreadPool.h:18:24: warning: no newline at end of file
    In file included from Server.cpp:48:
    ThreadPool.h:57:3: warning: no newline at end of file
    In file included from file.h:4,
                     from Server.cpp:49:
    In file included from Server.cpp:52:
    MemorySettingsReader.h:15:3: warning: no newline at end of file
                     from Server.cpp:53:
    In file included from Server.cpp:54:
    SQLiteFactory.h:7:3: warning: no newline at end of file
    In file included from PipeThrottler.h:1,
                     from Server.cpp:55:
    Interface/PipeThrottler.h:15:26: warning: no newline at end of file
    In file included from Server.cpp:55:
    PipeThrottler.h:21:3: warning: no newline at end of file
    In file included from Server.cpp:56:
    mt19937ar.h:10:29: warning: no newline at end of file
    mv -f .deps/Server.Tpo .deps/Server.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT ServerLinux.o -MD -MP -MF .deps/ServerLinux.Tpo -c -o ServerLinux.o ServerLinux.cpp
                     from ServerLinux.cpp:20:
    mv -f .deps/ServerLinux.Tpo .deps/ServerLinux.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT ServiceAcceptor.o -MD -MP -MF .deps/ServiceAcceptor.Tpo -c -o ServiceAcceptor.o ServiceAcceptor.cpp
                     from ServiceAcceptor.cpp
                     from ServiceAcceptor.cpp:24:
    In file included from ServiceWorker.h:4,
                     from ServiceAcceptor.cpp:26:
                     from ServiceWorker.h:5,
    In file included from ServiceWorker.h:5,
    In file included from ServiceWorker.h:7,
    mv -f .deps/ServiceAcceptor.Tpo .deps/ServiceAcceptor.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT ServiceWorker.o -MD -MP -MF .deps/ServiceWorker.Tpo -c -o ServiceWorker.o ServiceWorker.cpp
                     from ServiceWorker.cpp:3:
                     from ServiceWorker.cpp:4:
                     from ServiceWorker.cpp:5:
    mv -f .deps/ServiceWorker.Tpo .deps/ServiceWorker.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT SessionMgr.o -MD -MP -MF .deps/SessionMgr.Tpo -c -o SessionMgr.o SessionMgr.cpp
                     from SessionMgr.cpp:21:
                     from SessionMgr.cpp:22:
    mv -f .deps/SessionMgr.Tpo .deps/SessionMgr.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT StreamPipe.o -MD -MP -MF .deps/StreamPipe.Tpo -c -o StreamPipe.o StreamPipe.cpp
                     from StreamPipe.cpp:22:
                     from StreamPipe.cpp:26:
    In file included from StreamPipe.cpp:27:
    StreamPipe.cpp:275:2: warning: no newline at end of file
    mv -f .deps/StreamPipe.Tpo .deps/StreamPipe.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT Template.o -MD -MP -MF .deps/Template.Tpo -c -o Template.o Template.cpp
                     from Template.cpp:20:
                     from Template.cpp:24:
    mv -f .deps/Template.Tpo .deps/Template.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT WorkerThread.o -MD -MP -MF .deps/WorkerThread.Tpo -c -o WorkerThread.o WorkerThread.cpp
    In file included from WorkerThread.h:2,
                     from WorkerThread.cpp:22:
                     from WorkerThread.h:3,
    In file included from WorkerThread.h:3,
                     from WorkerThread.cpp:23:
                     from WorkerThread.cpp:24:
                     from WorkerThread.cpp:25:
                     from WorkerThread.cpp:26:
    In file included from WorkerThread.cpp:26:
    In file included from WorkerThread.cpp:28:
    WorkerThread.cpp:342:2: warning: no newline at end of file
    mv -f .deps/WorkerThread.Tpo .deps/WorkerThread.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT main.o -MD -MP -MF .deps/main.Tpo -c -o main.o main.cpp
                     from main.cpp:21:
                     from main.cpp:22:
                     from main.cpp:22:
                     from main.cpp:22:
                     from main.cpp:22:
                     from main.cpp:23:
                     from main.cpp:23:
                     from main.cpp:23:
                     from main.cpp:23:
                     from main.cpp:23:
    mv -f .deps/main.Tpo .deps/main.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT md5.o -MD -MP -MF .deps/md5.Tpo -c -o md5.o md5.cpp
    In file included from md5.cpp:49:
    mv -f .deps/md5.Tpo .deps/md5.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT stringtools.o -MD -MP -MF .deps/stringtools.Tpo -c -o stringtools.o stringtools.cpp
    mv -f .deps/stringtools.Tpo .deps/stringtools.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT fastcgi.o -MD -MP -MF .deps/fastcgi.Tpo -c -o fastcgi.o `test -f 'libfastcgi/fastcgi.cpp' || echo './'`libfastcgi/fastcgi.cpp
                     from libfastcgi/fastcgi.cpp:13:
    mv -f .deps/fastcgi.Tpo .deps/fastcgi.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT Mutex_lin.o -MD -MP -MF .deps/Mutex_lin.Tpo -c -o Mutex_lin.o Mutex_lin.cpp
    In file included from Mutex_lin.h:1,
                     from Mutex_lin.cpp:19:
                     from Mutex_lin.cpp:20:
    mv -f .deps/Mutex_lin.Tpo .deps/Mutex_lin.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT LoadbalancerClient.o -MD -MP -MF .deps/LoadbalancerClient.Tpo -c -o LoadbalancerClient.o LoadbalancerClient.cpp
                     from LoadbalancerClient.cpp:20:
    In file included from LoadbalancerClient.cpp:21:
    mv -f .deps/LoadbalancerClient.Tpo .deps/LoadbalancerClient.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT DBSettingsReader.o -MD -MP -MF .deps/DBSettingsReader.Tpo -c -o DBSettingsReader.o DBSettingsReader.cpp
                     from DBSettingsReader.cpp:22:
    In included from Server.h:13,
                     from DBSettingsReader.cpp:24:
    mv -f .deps/DBSettingsReader.Tpo .deps/DBSettingsReader.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT file_common.o -MD -MP -MF .deps/file_common.Tpo -c -o file_common.o file_common.cpp
                     from file_common.cpp:19:
                     from file_common.cpp:21:
    mv -f .deps/file_common.Tpo .deps/file_common.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT file_fstream.o -MD -MP -MF .deps/file_fstream.Tpo -c -o file_fstream.o file_fstream.cpp
                     from file_fstream.cpp:20:
    In file included from file_fstream.cpp:21:
    mv -f .deps/file_fstream.Tpo .deps/file_fstream.Po
    g++ -DHAVE_CONFIG_H -I.    -pthread -DLINUX -g -O2 -MT file_linux.o -MD -MP -MF .deps/file_linux.Tpo -c -o file_linux.o file_linux.cppIZlibDecompression.h:15:30: warning: no newline at end of file
In file included from pluginmgr.cpp:21:
CryptoFactory.h:17:3: warning: no newline at end of file
libtool: compile:  g++ -DHAVE_CONFIG_H -I. -DLINUX -I/usr/include -g -O2 -MT pluginmgr.lo -MD -MP -MF .deps/pluginmgr.Tpo -c pluginmgr.cpp -o pluginmgr.o >/dev/null 2>&1
mv -f .deps/pluginmgr.Tpo .deps/pluginmgr.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I.    -DLINUX -I/usr/include -g -O2 -MT AESEncryption.lo -MD -MP -MF .deps/AESEncryption.Tpo -c -o AESEncryption.lo AESEncryption.cpp
libtool: compile:  g++ -DHAVE_CONFIG_H -I. -DLINUX -I/usr/include -g -O2 -MT AESEncryption.lo -MD -MP -MF .deps/AESEncryption.Tpo -c AESEncryption.cpp  -fPIC -DPIC -o .libs/AESEncryption.o
In file included from AESEncryption.h:2,
                 from AESEncryption.cpp:19:
cryptopp_inc.h:32:7: warning: no newline at end of file
In file included from AESEncryption.h:4,
IAESEncryption.h:16:7: warning: no newline at end of file
In file included from AESEncryption.cpp:19:
AESEncryption.h:23:3: warning: no newline at end of file
libtool: compile:  g++ -DHAVE_CONFIG_H -I. -DLINUX -I/usr/include -g -O2 -MT AESEncryption.lo -MD -MP -MF .deps/AESEncryption.Tpo -c AESEncryption.cpp -o AESEncryption.o >/dev/null 2>&1
mv -f .deps/AESEncryption.Tpo .deps/AESEncryption.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I.    -DLINUX -I/usr/include -g -O2 -MT ZlibCompression.lo -MD -MP -MF .deps/ZlibCompression.Tpo -c -o ZlibCompression.lo ZlibCompression.cpp
libtool: compile:  g++ -DHAVE_CONFIG_H -I. -DLINUX -I/usr/include -g -O2 -MT ZlibCompression.lo -MD -MP -MF .deps/ZlibCompression.Tpo -c ZlibCompression.cpp  -fPIC -DPIC -o .libs/ZlibCompression.o
In file included from ZlibCompression.h:1,
                 from ZlibCompression.cpp:1:
IZlibCompression.h:15:28: warning: no newline at end of file
In file included from ZlibCompression.h:3,
In file included from ZlibCompression.cpp:1:
ZlibCompression.h:14:3: warning: no newline at end of file
ZlibCompression.cpp:28:2: warning: no newline at end of file
libtool: compile:  g++ -DHAVE_CONFIG_H -I. -DLINUX -I/usr/include -g -O2 -MT ZlibCompression.lo -MD -MP -MF .deps/ZlibCompression.Tpo -c ZlibCompression.cpp -o ZlibCompression.o >/dev/null 2>&1
mv -f .deps/ZlibCompression.Tpo .deps/ZlibCompression.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H -I.    -DLINUX -I/usr/include -g -O2 -MT ZlibDecompression.lo -MD -MP -MF .deps/ZlibDecompression.Tpo -c -o ZlibDecompression.lo ZlibDecompression.cpp
libtool: compile:  g++ -DHAVE_CONFIG_H -I. -DLINUX -I/usr/include -g -O2 -MT ZlibDecompression.lo -MD -MP -MF .deps/ZlibDecompression.Tpo -c ZlibDecompression.cpp  -fPIC -DPIC -o .libs/ZlibDecompression.o
In file included from ZlibDecompression.h:1,
                 from ZlibDecompression.cpp:1:
In file included from ZlibDecompression.h:3,
In file included from ZlibDecompression.cpp:1:
ZlibDecompression.h:12:3: warning: no newline at end of file
ZlibDecompression.cpp:37:2: warning: no newline at end of file
libtool: compile:  g++ -DHAVE_CONFIG_H -I. -DLINUX -I/usr/include -g -O2 -MT ZlibDecompression.lo -MD -MP -MF .deps/ZlibDecompression.Tpo -c ZlibDecompression.cpp -o ZlibDecompression.o >/dev/null 2>&1
mv -f .deps/ZlibDecompression.Tpo .deps/ZlibDecompression.Plo
/bin/sh ./libtool --tag=CXX   --mode=link g++ -DLINUX -I/usr/include -g -O2 -L/usr/lib  -o liburbackupserver_cryptoplugin.la -rpath /share/HDA_DATA/urbackup/install/lib dllmain.lo AESDecryption.lo CryptoFactory.lo pluginmgr.lo AESEncryption.lo ZlibCompression.lo ZlibDecompression.lo -lcryptopp
libtool: link: g++ -shared -nostdlib /share/HDA_DATA/.qpkg/Optware/bin/../lib/gcc/arm-none-linux-gnueabi/4.2.3/../../../../arm-none-linux-gnueabi/lib/crti.o /share/HDA_DATA/.qpkg/Optware/bin/../lib/gcc/arm-none-linux-gnueabi/4.2.3/crtbeginS.o  .libs/dllmain.o .libs/AESDecryption.o .libs/CryptoFactory.o .libs/pluginmgr.o .libs/AESEncryption.o .libs/ZlibCompression.o .libs/ZlibDecompression.o   -L/usr/lib -lcryptopp -L/share/HDA_DATA/.qpkg/Optware/bin/../lib/gcc/arm-none-linux-gnueabi/4.2.3 -L/share/HDA_DATA/.qpkg/Optware/bin/../lib/gcc -L/share/HDA_DATA/.qpkg/Optware/bin/../lib/gcc/arm-none-linux-gnueabi/4.2.3/../../../../arm-none-linux-gnueabi/lib -L/share/HDA_DATA/.qpkg/Optware/bin/../lib/gcc/arm-none-linux-gnueabi/4.2.3/../../.. -lstdc++ -lm -lc -lgcc_s /share/HDA_DATA/.qpkg/Optware/bin/../lib/gcc/arm-none-linux-gnueabi/4.2.3/crtendS.o /share/HDA_DATA/.qpkg/Optware/bin/../lib/gcc/arm-none-linux-gnueabi/4.2.3/../../../../arm-none-linux-gnueabi/lib/crtn.o    -Wl,-soname -Wl,liburbackupserver_cryptoplugin.so.0 -o .libs/liburbackupserver_cryptoplugin.so.0.0.0
/usr/lib/libcryptopp.so: file not recognized: File truncated
make[3]: *** [liburbackupserver_cryptoplugin.la] Error 1
make[3]: Leaving directory `/share/HDA_DATA/temp/urbackup-server-1.2.4.304/cryptoplugin'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/share/HDA_DATA/temp/urbackup-server-1.2.4.304/cryptoplugin'
make[1]: Leaving directory `/share/HDA_DATA/temp/urbackup-server-1.2.4.304'
This is way easier now, can use the QTS web interface to load it… download the right version (link below) then from the APP center inside the QNAP NAS load the correct version, it will install and run (QNAP IP with port 55414 at the end).
Works on:
  • ARM (64 bit only)
  • Intel x86 and x64
  • AMD x86 and x64
We have tried it on both Intel and AMD, currently using it on a 12 bay AMD high end NAS, its fast with transfers running at almost 1Gb sustained speeds.
