Disc is partitioned into 3 parts:
C: Windows 7
D: Windows XP
E: DATA
I wants to restore only C: partition with not working operating system from full image backup of C: partition, keeping D, E partitions untouched. It is possible?
When try to restore using recoverycd v1.0WIP3, seem that there in not such options.
PS: Restore wizard probably sees the disks as non-raid 1 volume, because i must select one in first step of recovery.
Thanx for reply, so data will be on the same place just c patition will be overwriten, thats cool. But when i try to recover at this state most probably it wilĺ destruct raid volume?
Then maybe will be good to switch recovery volume to offline contine on demand mode using utility and then restore c partition and then plug second recovery disc and turn mirroring back.
