So, a couple of questions here…
I have a file backups going from one machine to the UrBackup server via the internet. I have a full backup with incremental backups daily. If I want to just grab the “complete” backup (meaning, the complete file set on the original machine), how do I do that? I had thought that the “current” folder was somehow the symlink version of that. So, I was thinking I could just copy that folder. But, that appears to not be the case. Is there a way to (on the UrBackup server… currently a Windows 10 box) copy the complete file set? I mean, traditionally, with incrememental backups, you would restore the full, then each incremental in chronological order… which sucks (hence diffs, etc.). So, what am I missing here?
In general, I guess I am asking how you restore all files from the server and would like a couple scenarios…
- On the client (since the web UI gives me the ability to “restore” but is again on every incremental)
- On the server machine itself (as in, copy to a USB drive or something)
Thanks in advance.
Have you seen: UrBackup - Server administration manual
If you wanted the current edition, you could indeed perform a full copy from the current folder, and generate a repository with all the files up to that point.
Thanks, BrainWave… I have reviewed the manual. However, the manual seems to cover this pretty lightly. I get that the client can download the files. But, I don’t see how it has covered the backup folder structure in any detail.
As for the copy process, my experience is a bit different than what you explain. If I copy (specifically, robocopy [current] [destination] /s v/ /e) the current folder, my results are a much smaller folder (in terms of total size). If, on the other hand, I download the files from the UI, I can indeed get all the files.
It would seem that this process could use a bit more documentation. To be clear, I am sure there is a way to make this all work… and I am sure my knowledge of this process is the weak point here. I am just looking for some definitive info on how this is intended to work.
I appreciate any support.
