hello
i have full image and several incremental VHDs
main image mounted ok and all needed files is copied
but i can’t mount incremental images
start_urbackup_server --mountvhd gives no result
Using temporary mountpoint /mnt/tmp1 Loading FUSE kernel module... Starting VHD background process.. Starting mounting... mount: enabling autoclear loopdev flag mount: going to use the loop device /dev/loop0 /mnt/tmp1/volume: No such file or directory /mnt/tmp1/volume: No such file or directory mount: failed setting up loop device
vdfuse said “ERROR: opening vbox image failed”
–assemble gives strange output
start_urbackup_server --assemble Image_C_160603-1347.vhd --assemble_output /mnt/tmp1 /usr/sbin/start_urbackup_server: 262: [: x/mnt/tmp1: unexpected operator 2016-09-04 18:55:37: Loaded -url- plugin 2016-09-04 18:55:37: Loaded -cryptoplugin- plugin 2016-09-04 18:55:37: ERROR: Could not open MBR file "Image_C_160603-1347.vhd".mbr
what else can i do?
