Hello
I’m a newbie of Urbackup.
I’m intrested in installa Urbackup on my synology DS918+ .
Can you suggest a tutorial for install last version or Urbackup?
My best regards
Hello
My best regards
You can download this package :
https://github.com/josef109/spksrc/releases/download/2.4.12/urbackup_x86-6.1_2.4.12-1.spk
And install this manually in Synology package’s center.
Great!
If I want to update I’ve to install another spk ?
my best regards
Exactly
Great @Tisoru.
Excuseme: wich is the difference between the spk pakage and the container ?
my best regards
Spk package is a native application and container is a « sub-environment » who contains the application.
Great @Tisoru !
I’ve DS918+ I’ve seen many package. Wich is right for ds918+?
Do you have a list of compatibility ?
My best regards
Great Work!
I’ve installed and worked immediately.
Thanks to everyone for support!
@Tisoru next week I’ll receive new DS920 + and I want to migrate URBackup in that nas.
If I install SPK and I copy the content of the /volume1/urbackup from the old nas, is enough to perform the migration ?
My best regards
I’m not sur but I think it’s enough.
Hi
I’ve installed the package but can’t get inside the web interface at 55414 port, no response. Which steps also should I perform to get it running?
I think that docker container is better option. Frequent and easy updates.
Hallo Leute,
Vielleicht kann mir jemand weiterhelfen.
Habe eine DS1517+ mit der Version 7.0.
Würde gerne Urbackup installieren, leider kann ich die hier angegebene .spk Version nicht installieren.
Weiss jemand Rat?
Danke und Grüße
Hy.
i want to install UrBackup on Synology RS3618xs with DSM 6.2.2-24922 and my Package Center is not working…
Which is the right version of UrBackup for this DSM version? Does anybody have a link?
Thank you.
Hello guys,
I’m trying to install the package urbackup_x64-6.2.2_2.4.13-1.spk from https://github.com/josef109/spksrc/releases on a syno DS920+ (DSM 7.0.1-42218 update2) but I get an error when trying to install the .spk file from the package-center > install manually : “invalid format”.
Is it related to the CPU based on Geminilake arch ? (-> so, container setup?)
Thanks in advance for your help.
BR, vg
I just explained here what I tried to get UrBackup working on Synology.
Your best bet would be running it in Docker.
Thank you Adn77. I installed it in a docker and it seems to be working as expected.
BR, vg
