Hello all!.
I would like to exclude the “SteamLibrary” folder in my case. but i wish to do so no matter where it is located on the system or different drives. Also is it possible to set this as a global default?
Hello all!.
I’d add */SteamLibrary/steamapps;*/Steam/steamapps
Thanks! i will give it a go. For windows i would just invert the slashes to \ instead of / ?
That has been working for me…but you can always try it for yourself and test it out…
