how can I delete individual backups that I ran during testing? for example, how can I delete a dated backup such as this?
2015-09-23 04:11
thanks!
2015-09-23 04:11
thanks!
Currently the only way to do that is to delete the folders/image files from the storage and then run remove_unknown.bat
to also delete them from the database.
thanks. I’ll just let them be for now. after adding some files/folders to the exempt list, they’re not being transferred any longer.
having the ability to deleted files/folders in a future release would be a great addition.
