I have installed the new 2.0.30 upgrade onto the server and it is now stuck at the screen with the following:
UrBackup is upgrading its internal database. This may take a while. The server is inaccessible and will not do any backups during this upgrade.
Current version: 35
Target version: 47
Any idea how long this will take? Its been going for about 3 hours. CPU usage on the system seems low as well so not sure if it has hung or not. The backup_serverdb file in the urbackup directory is 3.8GB and urbackup_srv.exe is taking up 494mb of RAM.
Jamie
I guess it’ll all depend on if they change something in the DB or the way something is handled that will require parsing and updating the DB…
