I’m testing restore 2.0.1 using USB stick bootable and I need to find out how to saved an static IP for the client machine prior to restore via network. I understand that by default a DHCP IP is priority but when I input an static IP, it wasn’t saved. I found this out when I restart the boot process and I’m required to input the same static IP again.
It might be possible but a little bit complicated. Here are instructions:
This references the debian live manual which is sadly now offline. Here is a copy live-manual.portrait.en.a4.pdf (373.6 KB). See section 10.3 Persistence.
Why not make the iso persistence by default?
