The Administration Manual mentions “virtual clients”, but doesn’t give enough detail for me to figure out where you create these. I tried using the -v option to “urbackupclientctl add-backupdir” on the client end, but that didn’t appear to do anything.
Another issue I have, is I can’t figure out where to define include or exclude settings on the client end. Is there a way to define include/exclude on a PER-BACKUP-PATH basis or even a PER-VIRTUAL-CLIENT basis? On the server website, there is a place to set include/exclude, but apparently this affects every backup path on the client. I’m not sure if it affects every VIRTUAL client on the main client, because I have not been able to create one of those yet.
Is there any documentation on detailed client setup anywhere?
I have not worked with virtual clients, but the place to define them should be here:
in the GUI of the server go to settings; there is a drop down menue which is labeled “clients”; click on it and select the client you want to work with; you get a new view which is labeld “Client xxx”, below this select “Client”; on the bottom you find “Virtual sub client names”
probably you have to select “Separate settings for this client” before you are able to add virtual sub client names
