Sorry if it has been covered… tried searching through the forums…
But installed urbackup client unto a freshly installed SBS 2011 in VM for testing the software. I’m probably missing something but it does not seem to truncate the log files after backup?
in need of help. thanks.
2015-05-20 07:41:57: WARNING: Upgrading…
2015-05-20 07:41:57: ERROR: Error preparing Query [SELECT tvalue FROM misc WHERE tkey=‘db_version’]: no such table: misc
2015-05-20 07:41:57: ERROR: Error preparing Query [DROP INDEX filehashes_idx]: no such index: filehashes_idx
2015-05-20 08:00:14: WARNING: Snapshotting failed because of Writer. Retrying in 30s…
2015-05-20 08:01:07: WARNING: Snapshotting failed because of Writer. Retrying in 30s…
2015-05-20 08:02:35: WARNING: Writer Microsoft Exchange Writer has failure state VSS_WS_FAILED_AT_PREPARE_SNAPSHOT with error VSS_E_WRITERERROR_RETRYABLE. UrBackup will continue with the backup but the associated data may not be consistent.
2015-05-20 08:02:36: WARNING: Writer is in error state during snapshot creation. Writer data may not be consistent. This means the files open by this application (e.g. databases) will be backed up in a crash consistent state instead of a properly shutdown state. Properly written applications can recover from system crashes or power failures.
2015-05-20 08:19:36: WARNING: Writer Microsoft Exchange Writer has failure state VSS_WS_FAILED_AT_PREPARE_SNAPSHOT with error VSS_E_WRITERERROR_RETRYABLE. UrBackup will continue with the backup but the associated data may not be consistent.
2015-05-20 08:28:16: WARNING: Snapshotting failed because of Writer. Retrying in 30s…
2015-05-20 08:28:58: WARNING: Snapshotting failed because of Writer. Retrying in 30s…
2015-05-20 08:29:39: WARNING: Writer Microsoft Exchange Writer has failure state VSS_WS_FAILED_AT_PREPARE_SNAPSHOT with error VSS_E_WRITERERROR_RETRYABLE. UrBackup will continue with the backup but the associated data may not be consistent.
2015-05-20 08:29:39: WARNING: Writer is in error state during snapshot creation. Writer data may not be consistent. This means the files open by this application (e.g. databases) will be backed up in a crash consistent state instead of a properly shutdown state. Properly written applications can recover from system crashes or power failures.
2015-05-20 08:55:24: WARNING: Writer Microsoft Exchange Writer has failure state VSS_WS_FAILED_AT_PREPARE_SNAPSHOT with error VSS_E_WRITERERROR_RETRYABLE. UrBackup will continue with the backup but the associated data may not be consistent.
2015-05-22 02:15:49: WARNING: Snapshotting failed because of Writer. Retrying in 30s…
2015-05-22 02:16:32: WARNING: Snapshotting failed because of Writer. Retrying in 30s…
2015-05-22 02:17:12: WARNING: Writer Microsoft Exchange Writer has failure state VSS_WS_FAILED_AT_PREPARE_SNAPSHOT with error VSS_E_WRITERERROR_RETRYABLE. UrBackup will continue with the backup but the associated data may not be consistent.
2015-05-22 02:17:13: WARNING: Writer is in error state during snapshot creation. Writer data may not be consistent. This means the files open by this application (e.g. databases) will be backed up in a crash consistent state instead of a properly shutdown state. Properly written applications can recover from system crashes or power failures.
2015-05-22 02:43:20: WARNING: Writer Microsoft Exchange Writer has failure state VSS_WS_FAILED_AT_PREPARE_SNAPSHOT with error VSS_E_WRITERERROR_RETRYABLE. UrBackup will continue with the backup but the associated data may not be consistent.
