Help testing: UEFI enabled restore CD/USB stick
UrBackup Restore CD 1.2 will be able to restore GPT formatted hard disks and therefore should be able to boot (as easy as possible) with UEFI firmware. I need help testing this on as much different hardware with UEFI as possible.
Please test following:
  • The Restore CD boots without having to change anything in the EFI setup
  • The Restore CD works when Secure Boot is disabled
  • The Restore CD works in the Legacy BIOS mode
  • If it does only boot in Legacy BIOS mode: Other EFI enabled Linux based live cds work such as Knoppix ( http://www.knoppix.org/ )
The iso is available here: http://sourceforge.net/projects/urbackup/files/Restore/1.2WIP/urbackup_restore_1.2WIP.iso/download
Hi uroni,
I tried to boot with the restore CD 1.2WIP2 on a 2th generation vm on Hyper-V but it did not work. I also tried with the secure boot option disabled but with the same result. A Ubuntu Live-CD 14.04 is able to boot.
It also works to boot on a 1th generation vm.
Do you have any suggestions to solve this problem?
I am going to try this again, so far doesnt pick up the server 1.4.12
