Help needed to find problem
I really need help because I’m at a loss and can’t find any solution.
I’ve been using UrBackup Server version 2.4.15 on TrueNAS Core for years without any problems, and I’ve had complete confidence in it for backing up my professional clients’ data.
Not a single issue or error in 8 years.
Following a hardware failure, I decided to replace the server with more modern equipment — TrueNAS Scale, the latest version of UrBackup Server 2.5.33, and brand-new hard drives.
Since then, nothing has worked properly: the backup sizes no longer make sense, the database becomes corrupted after a few days and can’t be repaired, forcing me to restore from a backup every time (which triggers terabytes of synchronization and inconsistent values).
I’ve tested the hardware, even replaced the computer with another one, but nothing changes.
No command can regenerate the database from the existing backups, which means that all 8 TB of previous backups are lost and unusable each time.
Does anyone have a solution?
You have created lot of unknows with all the changes. That is asking for trouble.
I assume you made an image backup of your OS, urbackup, data backups.
Restore that for starters.
I don’t understand your answer—what does it have to do with my question?
I’m replying to myself
After 4 weeks of testing, troubleshooting issues, dealing with database corruption, restoring backups, and wasting time, I finally decided to roll back.
I reinstalled UrBackup Server 2.4.15 on the new TrueNAS Scale server (with custom app) and voilà! I now have consistent backups with correct backup values, and everything works properly.
In the end, the 2.4.x branch works very well — it’s stable in a production environment. So why bother going any further?
