Over last 3 days my Linux clients (two, one is on the urbackup server) have gone crazy.
Each has had over 30 incremental file backups run each day.
Been running a cleanup now for hours.
Max incremental backups setting is 32.
Just one shows as having 166 incremental file backups in the backup folder.
It takes about 2 minutes to delete one.
One is down to 163, the other is down to 39 incremental file backups.
Going to take a while to get town to 32 for the one.
I’ve disable all Linux backups until can get this resolved.
FYI - Backups show as successful. Server 2.2.8 Client 2.2.5
I am unsure how you got this , the interval is in hour , so if you put 1 , you d get max 24 backup per day not 30.
Can you show a screenshot of the settings you use?
You can run urbackupsrv cleanup (better look at the manual for exact syntax) that allow you to specify a disk space or backup number directly (you wont have to click and wait for deletion)
That s possible, if you also have archiving enabled, because archive don t count against max backup.
Or is it that the backup folder shows 166 folders, but not the ui?
As i said before , look at the cleanup command
The problem started when you updated to 2.2.8 , or when did changed some config?
I ran the remove-unknown command and it is deleting backups greater that 32.
One finished, the other is down to 106. The remove-unknown is showing the count each time it removes one.
Don’t know if it means anything, but they were starting about every 8 minutes.
Been running 2.2.8 for a while
I don’t do archiving. Here are settings.
Be carefull, the remove unknown is super long (takes 3 days for me).
Because it compares each files on the disk to the database.
If you dont want to spend a few day on this , maybe cancel while it still deleting backup like this.
The logs will look very different once its at th next step.
Still it s good to run it once in a while.
Hence why i suggested the cleanup , which just delete the unwanted backups.
What you may also check is for client side settings.
On the client you can also set some frequency for backups. (it s kinda confusing, i know)
So if you have a gui installed on the client just start it and look at them.
On linux you may read them via /usr/local/var/urbackup/data/settings.cfg
On windows that would be something like c:\program files\urbackup\settings.cfg
remove-unknown has never taken this long, obliviously because it never had this many backups to deal with, and nightly cleanup would take care of whatever was necessary.
I didn’t think to look at client side settings.
One thing I found that conflicts with Web tool is this:
allow_starting_full_image_backups_def=true
allow_starting_incr_image_backups_def=true
Maybe it doesn’t matter since Web tool says Image backups are not supported.
update_freq_incr_def=86400 <-- 86400 seconds in 24 hours
The deleting of files just finished.
Checked system clocks and they were OK.
Now still need to know why they run every 8 minutes or so.
The exponential backoff is 40 min. These were running every 7-8 minutes.
Since the Web tool indicated the backups were successful, I didn’t look at Server log.
Looks like I have a serious problem with the database.
These errors have been in there for a few days:
2018-03-16 00:03:54: ERROR: Backing up database failed. Copying urbackup/backup_server.db-wal to /PC_Backups/urbackup/backup_server.db-wal~ failed. No such file or directory (code: 2)
2018-03-16 00:03:56: ERROR: Backing up database failed. Copying urbackup/backup_server_settings.db-wal to /PC_Backups/urbackup/backup_server_settings.db-wal~ failed. No such file or di$
2018-03-16 00:04:03: ERROR: Backing up database failed. Copying urbackup/backup_server_files.db-wal to /PC_Backups/urbackup/backup_server_files.db-wal~ failed. No such file or director$
2018-03-16 00:04:05: ERROR: Backing up database failed. Copying urbackup/backup_server_links.db-wal to /PC_Backups/urbackup/backup_server_links.db-wal~ failed. No such file or director$
2018-03-16 00:04:07: ERROR: Backing up database failed. Copying urbackup/backup_server_link_journal.db-wal to /PC_Backups/urbackup/backup_server_link_journal.db-wal~ failed. No such fi$
I ran database-repair this morning.
No errors on screen, but these (9 of them) were in the log.
2018-03-17 09:01:28: WARNING: SQLite: statement aborts at 27: [UPDATE clients SET lastseen=datetime(?, ‘unixepoch’) WHERE id=?] attempt to write a readonly database errorcode: 1032
2018-03-17 09:01:28: ERROR: Error in CQuery::Execute - attempt to write a readonly database Stmt: [UPDATE clients SET lastseen=datetime(?, ‘unixepoch’) WHERE id=?]
