I am having trouble installing a new instance of urbackup on a Proxmox LXC Debian 12 container. I’m using the proxmox helper script:
bash -c “$(curl -fsSL https://raw.githubusercontent.com/community-scripts/ProxmoxVE/main/ct/urbackupserver.sh)”
It doesn’t seem to be a helper script issue but rather a repository problem.
Here is the error output:
E: Failed to fetch https://slc-mirror.opensuse.org/repositories/home%3A/uroni/Debian_12/amd64/urbackup-server_2.5.33.0-1_amd64.deb File has unexpected size (4377736 != 4378348). Mirror sync in progress? [IP: 195.135.220.50 443]
Hashes of expected file:
- SHA256:e94a9b356d29a4625459b901fd4cea04005255ab06c64a328bccaea7b16f2bb6
- SHA1:a5f35e65dbd9d7cb66f01138c553f9b3aa45ce11 [weak]
- MD5Sum:269ca5a7b3ff3b90c506abce0ec620cd [weak]
- Filesize:4378348 [weak]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
[ERROR] in line 25: exit code 0: while executing command apt-get install -y -qq urbackup-server
I’ve tried over the past week thinking it might be a mirror issue and would be fixed. I thought I’d see if it is a known problem. Thanks for any guidance.
