I’ve noticed that sometimes when my laptop (backup client) goes into standby mode and a backup job was running the backup job seems to hang forever when I resume the Laptop a bit later (I’m not sure about the exact timing. Could be 10-90 minutes later).
That’s what happened last time that it happened:
- Backup job was running. Switching laptop into stand by mode.
- Some time later (10-90 minutes???) I’ve resumed the laptop
- At some point, maybe 10-30 minutes after resuming, I’ve checked some stuff on the urbackup server and noticed the backup job from my laptop, which didn’t seem to get anywhere.
- checking the log on the server side, the last entries where from just before standby
- checking urbackupclientctl: it shows that it is connected and a backup is running, no log entries.
- I’ve waited for about an hour, but nothing changed.
- Then I’ve stopped the backup on the server side.
- I’ve waited for about another hour, but nothing happened, neither on server nor on client side.
- So I’ve restartet urbackupclientbackend on the laptop.
- Now urbackupclientctl showed that it was connected to the server, but no backup is ongoing
- Meanwhile the server continued the backup. There were new log entries of him copying files. After a few minutes (not more than 10) he noticed that the client was disappeared (restarted) at some point of time and printed out following:
17/09/19 11:17 DEBUG GT: Linked file “frachten.ibd”
17/09/19 11:17 DEBUG HT: Copying file to “/var/lib/urbackup/RMMbook/190917-1652/.hashes/mysql/fisch_web/frachtencodetabelle.ibd”
17/09/19 11:17 DEBUG GT: Linked file “frachtencodetabelle.ibd”
17/09/19 11:17 DEBUG HT: Copying file to “/var/lib/urbackup/RMMbook/190917-1652/.hashes/mysql/fisch_web/gapless_sequence.frm”
17/09/19 11:17 DEBUG GT: Linked file “gapless_sequence.frm”
17/09/19 11:17 DEBUG Copying incomplete file “tables_priv.MYI”
17/09/19 11:17 DEBUG Copying incomplete file “tables_priv.frm”
17/09/19 11:17 DEBUG Copying incomplete file “user.MYI”
17/09/19 11:17 DEBUG Copying incomplete file “user.frm”
17/09/19 11:17 INFO Waiting for file hashing and copying threads…
17/09/19 11:17 INFO Waiting for metadata download stream to finish
17/09/19 11:17 DEBUG Saved metadata of 232 files and directories. 100% done…
17/09/19 11:17 DEBUG Not all folder metadata could be applied. Metadata was inconsistent.
17/09/19 11:17 INFO Writing new file list…
17/09/19 11:17 DEBUG Some metadata was missing
17/09/19 11:17 INFO Number of copied file entries from last backup is 286823
17/09/19 11:17 DEBUG Client disconnected while backing up. Copying partial file…
17/09/19 11:17 DEBUG Syncing file system…
17/09/19 11:17 INFO Transferred 15.5765 MB - Average speed: 27.408 KBit/s
17/09/19 11:17 INFO (Before compression: 23.7818 MB ratio: 1.52678)
17/09/19 11:17 INFO 101.366 GB of files were already present on the server and did not need to be transferred
17/09/19 11:17 DEBUG Script does not exist urbackup/post_incr_filebackup
17/09/19 11:17 INFO Time taken for backing up client RMMbook: 1h 25m 11s
17/09/19 11:17 ERROR Backup failed
I’ve had similar issues before, but just ignored them.
There was one, of which I don’t know if it is related.
- A backup from a server was hanging for over 24 hours. Just doing nothing (no new log entries on the server or client).
- I’ve tried to stop the backup on the server side. After 24 hours it was still there.
- I’ve stopped the urbackupclientbackend on the client side. After 24 hours the backup was still there.
- I’ve started the urbackupclientbackend again and waited an other 3 days (I’ve forgot about it ;-)).
- The backupjob was still there. There was a virtual client on the same machine which meanwhile did all it’s backups without any problems. Meanwhile the main client couldn’t start any new backups, since the other one was hanging.
- Stopped the urbackup server
- Did a clean up (no idea if that is necessary)
- started the urbackup server again
- started urbackupclientbackend again
- The backupjob was finally gone and everything worked normally again.
I don’t know if the two behaviour above are related. It was the only time I can remember that I’ve had to restart the urbackupserver for a backupjob to disappear. Usually restarting the urbackupclientbackup is enough…
Both server and clients are running on Linux: Debian buster. Both use the actual urbackup version 2.3.8 for the server and 2.3.4 for the clients.
My laptop uses: “Beta: Calculate file hashes on client in parallel”
The other client machine where the backup was stuck for 5 days, doesn’t use that. That one is a server, so it’s online 24/7.
I know it’s not the best error description ever, but I’ve really got the feeling there’s a problem somewhere. I’d be happy to try to recreate the problem and provide logs, if it’s possible to get meaning full ones.
