Global Soft Filesystem Quota in ZFS
I’m using urbackup with a ZFS copy-on-write configuration for both file and image backups. It does not seem to respect the global soft filesystem quota and my storage is constantly out of space triggering emergency cleanups with every backup. Additionally, manual cleanups calculate “space to free” incorrectly (see below, tried to clean up 300G and only got 18G), although the “free space” is accurate. df -h is also accurate. Any thoughts on what I’m doing wrong?
root:~# urbackupsrv cleanup -a 300G -u root
2018-12-26 15:43:07: Shutting down all database instances…
2018-12-26 15:43:07: Opening urbackup server database…
2018-12-26 15:43:07: Testing if backup destination can handle subvolumes and snapshots…
Testing for btrfs…
ERROR: not a btrfs filesystem: /var/urbackup_files/testA54hj5luZtlorr494
Testing for zfs…
ZFS TEST OK
2018-12-26 15:43:10: Backup destination does handle subvolumes and snapshots. Snapshots enabled for image and file backups.
2018-12-26 15:43:10: Emulating reflinks via copying
2018-12-26 15:43:10: Cleaning up 18.462 GB on backup storage
2018-12-26 15:43:10: Database cache size is 1.95312 GB
2018-12-26 15:43:10: Starting cleanup…
2018-12-26 15:43:10: Freeing database connections…
2018-12-26 15:43:10: Space to free: 18.462 GB
2018-12-26 15:43:10: Free space: 17.8416 GB
is this quota you set on the filesystem or is it a quota you set as a limit in urbackup?
In Urbackup, the general setting of “Global Soft Filesystem Quota”
Can you have a look which fs has 17.8416 GB free space (as in the log above).
One known issue is that UrBackup uses the free space of the backup folder (configured on the web interface) to get the free space. So if you put files and images on different ZFS data sets you’ll have problems.
I believe that number is accurate (it’s the “space to free” which seems to be calculated incorrectly). All of urbackup’s paths are on different zfs data sets (config below), however they are all part of the same pool and share the same remaining free space.
Urbackup database path: /var/urbackup
Backup storage path setting: /var/urbackup_files
/etc/urbackup/backupfolder contents: /var/urbackup_files
/etc/urbackup/dataset contents: rpool/var/urbackup_files/images
/etc/urbackup/dataset_file contents: rpool/var/urbackup_files/files
How can I determine what UrBackup thinks is the total, and free space for it?
My Global soft filesystem quota is set to 95%
But the Urbackup Jail has a data volume with only 84% used space but it’s cleaning down to minimum backup level like it’s hitting the Global soft quota.
Could be this function is buggy on your systems: https://github.com/uroni/urbackup_backend/blob/2.3.x/urbackupcommon/os_functions_lin.cpp#L377
@silversword This looks like FreeNAS (FreeBSD)… true?
@dimoochka FreeBSD as well?
Ubuntu 18.04 LTS for me (I think I had the same issue on 16.04 LTS previously)
Yes, this is FreeNAS-11.1-U6
I figured out the problem. UrBackup uses df to determine total filesystem capacity and calculates how much cleanup it needs to do based on that value. df reports this value incorrectly on ZFS because df calculates Size (total capacity) by simply summing Used+Avail. This methodology is incorrect when applied to a zfs dataset, because it does not account for the space used by all the other datasets on the same pool. See example outputs below:
# df -h
Filesystem                                                             Size  Used Avail Use% Mounted on
rpool/srv                                                              132G  128K  132G   1% /srv
rpool/var/games                                                        136G  3.8G  132G   3% /var/games
rpool/var/share                                                        197G   65G  132G  34% /var/share
rpool/var/urbackup                                                     132G  710M  132G   1% /var/urbackup
The Size that df reports ranges from 132G-197G, despite the fact that all datasets reside on the same pool. This breaks the Global Soft Filesystem Quota option on ZFS, eventually causing the system to run out of space.
# zfs list rpool
NAME    USED  AVAIL  REFER  MOUNTPOINT
rpool  3.38T   131G   128K  /
The actual pool capacity as reported by ZFS is 3.38T + 131G. This seems to be the most accurate method for addressing the problem within UrBackup’s existing workflow. For scripting purposes, you can use:
# zfs list -Hp rpool
rpool   3716467060944   140937858864    130944  /
Also, to clarify, if UrBackup does NOT use df, the problem is (as you mentioned) in os_total_space()
Looking at the code, the function relies on statvfs64() which probably reports f_blocks incorrectly (I wonder if statvfs64() is also used in df).
Yeah, UrBackup uses the same logic as df to get filesystem total space.
Doeas it help if you create a hierarchy like:
rpool/root
rpool/root/srv
rpool/root/var/games
rpool/root/var/share
rpool/root/var/urbackup
then point UrBackup at the mount path of rpool to get total space?
Testing from the shell of the jail running Urbackup on FreeNAS 11.6:
root@UrBackup:/ # df -h
Filesystem               Size    Used   Avail Capacity  Mounted on
SSD1tb/jails/UrBackup    695G    9.3G    685G     1%    /
root@UrBackup:/ # df -h /mnt/UrBackupData/
/mnt/data/UrBackupData     30T     25T    4.1T    86%    [restricted]
root@UrBackup:/ #
If df would query the actual data path instead of the system running Urbackup I think it would solve the problem in all cases.
Unfortunately I think ZFS’s implementation of statvfs64 is totally unsuitable for this use case. Here are some tests;
# zfs list
rpool                                3.39T   118G   128K  /
rpool/var                            2.74T   118G   128K  /var
rpool/var/urbackup                   735M   118G   735M  /var/urbackup
rpool/var/urbackup_files             2.66T   118G   649M  /var/urbackup_files
rpool/var/urbackup_files/files       1.38T   118G   128K  /var/urbackup_files/files
... hundreds of subvolumes ...
rpool/var/urbackup_files/images      1.28T   118G   128K  /var/urbackup_files/images
— Notice how rpool/var/urbackup_files contains 2.6T of data (spanned across two child filesystems) with 118G available —
# df -h
rpool/var/urbackup                  119G  735M  119G   1% /var/urbackup
rpool/var/urbackup_files            119G  649M  119G   1% /var/urbackup_files
rpool/var/urbackup_files/files      119G  128K  119G   1% /var/urbackup_files/files
rpool/var/urbackup_files/images     119G  128K  119G   1% /var/urbackup_files/images
— df reports that rpool/var/urbackup_files contains 119G of data (649M of data on that filesystem only, NOT including child filesystems, plus 119G available, apparently rounded down) —
Now see output of df on rpool root mounted on /var/test (like you had requested)
# df -h /var/test
rpool           119G  128K  119G   1% /var/test
Same issue as above. When calculating free space on zfs filesystems, df ONLY accounts for that specific filesystem without including space occupied by child or sibling filesystems in the same pool. This situation becomes unavoidable when using UrBackup’s ZFS COW feature for image/file backups because it creates a new child filesystem for each backup.
What does df -h /var say?
Output as below; my / (and /var) path is actually a separate filesystem ( rpool/var is not mounted but rpool/var/urbackup_files, rpool/var/spool, etc. are)
# df -h /var
/dev/mapper/vgroup-root   26G   14G   11G  56% /
If I mounted rpool/var (pain in the butt with the way I have my system set up), it would be an empty filesystem with a bunch of other filesystems mounted on top of it and I expect output would look similar to the pattern seen on previous posts (rpool, rpool/var/xxx, rpool/var/xxx/xxx, etc.) :
# df -h /var
rpool/var           119G  128K  119G   1% /var
