I am fairly new to UrBackup so this can be a rookie mistake. However: I am failing to get UrBackup to work for imaged based backups. I already checked all the forum posts regarding that issue, none of them leaded to a solution.
Setup
Server:
Infscape Appliance
(Shell-install on fresh Debian 11 on a Hetzner Cloudserver)
System version: 11.43
Linux kernel version: Linux 5.10.226
Based on: Debian GNU/Linux
Client:
Windows Server 2022 21H2 (all the latest updates applied)
UrBackup Client 2.5.25
Issue:
- After starting an Full image based backup it fails with the following error message:
21.12.24 00:16 INFO Starting unscheduled full image backup of volume "C:"...
21.12.24 00:16 DEBUG Backing up SYSVOL...
21.12.24 00:16 DEBUG Backing up SYSVOL done.
21.12.24 00:16 DEBUG Backing up EFI System Partition...
21.12.24 00:16 DEBUG Backing up EFI System Partition done.
21.12.24 00:16 INFO Basing image backup on last incremental or full image backup
21.12.24 00:16 WARNING Error retrieving last image backup. Doing full image backup instead.
21.12.24 00:17 ERROR Could not read MBR
21.12.24 00:17 ERROR Cannot retrieve master boot record (MBR) for the disk from the client.
21.12.24 00:17 INFO Time taken for backing up client XX.XXX.com: 1m 2s
21.12.24 00:17 ERROR Backup failed
debug.log
4-12-21 00:16:10: ClientService cmd: STATUS DETAIL#pw=XXX
2024-12-21 00:16:10: Started connection to SERVICE_COMMANDS
2024-12-21 00:16:10: ClientService cmd: #I5TQVOqYja0S5ZzRgNaPZ#MBR driveletter=SYSVOL&disk_path=SYSVOL&image_full=1&running_jobs=1&token=XXX
2024-12-21 00:16:10: rc=0 hasError=true state=0
2024-12-21 00:16:10: SERVICE_COMMANDS finished
2024-12-21 00:16:11: ClientService cmd: STATUS DETAIL#pw=XXX
(... some status pings here...)
2024-12-21 00:16:20: ClientService cmd: STATUS DETAIL#pw=XXX
2024-12-21 00:16:20: Started connection to SERVICE_COMMANDS
2024-12-21 00:16:20: ClientService cmd: #I5TQVOqYja0S5ZzRgNaPZ#FULL IMAGE letter=SYSVOL&token=XXX&bitmap=1&status_id=31&running_jobs=1&zero_skipped=1
2024-12-21 00:16:20: Filesystem type is ntfs (\\?\Volume{b0debac4-0000-0000-0000-100000000000})
2024-12-21 00:16:20: TotalNumberOfClusters=25599 numberOfClusters=25599 n_clusters=3200 StartingLcn=0 BitmapSize=25599 r_bytes=3216
2024-12-21 00:16:20: FSINFO: blocksize=4096 size=104857088 has_error=false used_space=29134848 type=ntfs_win
2024-12-21 00:16:21: Sending full image done
2024-12-21 00:16:21: Removing running process (1) id 3 server_id 31 token 8LDeiBIgIfu3Pz9V4CTw action 3
2024-12-21 00:16:21: Service finished. Transferred 12.3596 MB
2024-12-21 00:16:21: SERVICE_COMMANDS finished
2024-12-21 00:16:21: ClientService cmd: STATUS#pw=XXX
(... some status pings here ...)
2024-12-21 00:16:31: ClientService cmd: STATUS DETAIL#pw=XXX
2024-12-21 00:16:31: Started connection to SERVICE_COMMANDS
2024-12-21 00:16:31: ClientService cmd: #I5TQVOqYja0S5ZzRgNaPZ#MBR driveletter=ESP&disk_path=ESP&image_full=1&running_jobs=1&token=XXX
2024-12-21 00:16:31: rc=0 hasError=true state=0
2024-12-21 00:16:31: SERVICE_COMMANDS finished
2024-12-21 00:16:32: ClientService cmd: PONG
2024-12-21 00:16:32: ClientService cmd: STATUS DETAIL#pw=XXX
2024-12-21 00:16:41: ClientService cmd: STATUS DETAIL#pw=XXX
2024-12-21 00:16:42: Started connection to SERVICE_COMMANDS
2024-12-21 00:16:42: ClientService cmd: #I5TQVOqYja0S5ZzRgNaPZ#FULL IMAGE letter=ESP&token=XXX&bitmap=1&status_id=32&running_jobs=1&zero_skipped=1
2024-12-21 00:16:42: ERROR: Not found
2024-12-21 00:16:42: rc=0 hasError=true state=0
2024-12-21 00:16:42: SERVICE_COMMANDS finished
2024-12-21 00:16:42: ClientService cmd: STATUS DETAIL#pw=XXX
2024-12-21 00:16:52: ClientService cmd: STATUS DETAIL#pw=XX
2024-12-21 00:16:52: Started connection to SERVICE_COMMANDS
2024-12-21 00:16:52: ClientService cmd: #I5TQVOqYja0S5ZzRgNaPZ#2PING RUNNING pc_done=0&status_id=30&speed_bpms=0&total_bytes=-1&done_bytes=0&paused_fb=1#token=XXX
2024-12-21 00:16:53: ClientService cmd: STATUS DETAIL#pw=XXX
2024-12-21 00:17:02: ClientService cmd: STATUS DETAIL#pw=XXX
2024-12-21 00:17:02: ClientService cmd: #I5TQVOqYja0S5ZzRgNaPZ#2PING RUNNING pc_done=0&status_id=30&speed_bpms=0&total_bytes=-1&done_bytes=0&paused_fb=1#token=XXX
2024-12-21 00:17:03: ClientService cmd: STATUS DETAIL#pw=XXX
DETAIL#pw=XXX
2024-12-21 00:17:12: rc=0 hasError=true state=0
2024-12-21 00:17:12: SERVICE_COMMANDS finished
2024-12-21 00:17:13: ClientService cmd: STATUS#pw=XXX
2024-12-21 00:17:13: ClientService cmd: STATUS DETAIL#pw=XXX
2024-12-21 00:17:13: Started connection to SERVICE_COMMANDS
2024-12-21 00:17:13: ClientService cmd: #I5TQVOqYja0S5ZzRgNaPZ#2LOGDATA 1734735380 0-1734735325-Starting unscheduled full image backup of volume "C:"...
0-1734735367-Basing image backup on last incremental or full image backup
1-1734735367-Error retrieving last image backup. Doing full image backup instead.
2-1734735377-Could not read MBR
2-1734735377-Cannot retrieve master boot record (MBR) for the disk from the client.
0-1734735380-Time taken for backing up client XX.XXX.com: 55s
2-1734735380-Backup failed
2024-12-21 00:17:13: rc=0 hasError=true state=0
2024-12-21 00:17:13: SERVICE_COMMANDS finished
What I already tried to resolve the issue
- ran chkdsk on C:
- Researched this forum for a solution
Any help would be greatly appreciated.
