My frustrating situation right now: Running a urBackup docker on unRaid. Everything is working perfectly. Now I need to shift all data on drive 1 to drive 2, because drive 1 shall be replaced by drive 2 simply because of more space needed in general for the array.
with the command: rsync -avX /mnt/disk1/ /mnt/disk2
would do the job. But right now I am sitting here after 30 hours, the destination drive having 3 times the data of the source drive and thinking something cant be right, as the cloning is still under it’s way.
Now I thought about incremental backups and from what I understood, somehow “hard-links” are being used in those incremental backups which should be the main problem in my situation, right?
MY question: Is there any way to make this work properly? Some options in rsync in order to properly sync those 2 drives so that I can replace the older one, put in the new “rsynce’d” one and move on as nothing happend?
Failing that your next best bet is to side-step the filesystem hard link issues by doing some sort of bitwise clone (dd or similar) & then expand the filesystem on the new storage.
To preserve hard links with rsync you need to add the -H flag:
-H, --hard-links
This tells rsync to look for hard-linked files in the transfer and link together the corresponding files on the receiving side. Without this option, hard-linked files in the transfer are treated as though they were separate files.
After copying you should run remove_unknown to correct the symbolic links (and you shouldn’t run backups during copying).
Hello, i want to make a 3-2-1 backup scheme. Im running urBackup inside truenas core and i would like to clone/backup the dataset where urbackup holds the backups and config files. Im testing with rsync and also have read about kopia to keep a clone of this dataset on an external HDD and also at backblaze bucket.
I will make this incremental but i would like to know if anybody can share experiences doing this. I cant run another urBackup server because i need information to be encrypted.
I’m using this command with rsync
rsync -av -H --progress --delete /mnt/nas/urBackup/ /mnt/backup/urbackup/
is this correct?
