Hi there,
I ran into a filebackup-not-starting issue, I hope someone can help me with.
last week I installed a fresh urbackup server instance (v2.2.8 Debian armhf) on a new RaspberryPi 3B+. On my Windows 10 machine I installed the latest Windows client (v2.2.5). Server and client are seeing each other fine and a backup of the system partition already went through without problems.
Unfortunately whenever I try to start a filebackup, the client is not able to index the files. I always get an error finished with "error - prefilebackup script failed with error code 1".
What I’ve already tried so far:
- Installed the client on an different Windows 10 machine: Filebackup was created with no problem.
- Removed and reinstalled client with default settings (full file backup): Always getting the same error.
- Searched the forum but found no comparable issue.
- Tinkered with the prefilebackup.bat script: No results.
These are the log files:
Client:
2018-03-23 09:01:01: ClientService cmd: START BACKUP FULL#pw=YPiq<...>1ukk
2018-03-23 09:01:01: rc=0 hasError=true state=0
2018-03-23 09:01:01: ClientService cmd: #Iol<...>Kzy#2PING RUNNING pc_done=&status_id=4&speed_bpms=0&total_bytes=-1&done_bytes=0&paused_fb=1#token=JEr<...>8MWCl
2018-03-23 09:01:01: ClientService cmd: #Iol<...>Kzy#3START FULL BACKUP group=0&running_jobs=1&sha=528&with_permissions=1&with_scripts=1&with_orig_path=1&with_sequence=1&with_proper_symlinks=1&status_id=4&async=1#token=JEr<...>8MWCl
2018-03-23 09:01:01: Async index 9a48<...>22cf
2018-03-23 09:01:01: Removing VSS log data...
2018-03-23 09:01:01: Final path: D:\Work
2018-03-23 09:01:01: Script list at "C:\Program Files\_system\UrBackup\backup_scripts\list.bat" does not exist. Skipping.
2018-03-23 09:01:01: Deleting files... doing full index...
2018-03-23 09:01:01: ClientService cmd: #Iol<...>Kzy#WAIT FOR INDEX async_id=9a48<...>22cf#token=JEr<...>8MWCl
2018-03-23 09:01:01: Wait for async index 9a48<...>22cf
2018-03-23 09:01:02: Async index 9a48<...>22cf finished with "error - prefilebackup script failed with error code 1"
2018-03-23 09:01:02: ClientService cmd: #Iol<...>Kzy#GET VSSLOG
2018-03-23 09:01:02: VSS logdata - 14 bytes
2018-03-23 09:01:02: rc=0 hasError=true state=0
2018-03-23 09:01:03: ClientService cmd: STATUS#pw=YPiq<...>1ukk
2018-03-23 09:01:11: rc=0 hasError=true state=0
2018-03-23 09:01:12: ClientService cmd: #Iol<...>Kzy#2LOGDATA 1521792072 0-1521792062-Starting unscheduled full file backup...
2-1521792063-Constructing of filelist of "Quboid" failed: error - prefilebackup script failed with error code 1
2-1521792072-Backup had an early error. Deleting partial backup.
2018-03-23 09:01:12: rc=0 hasError=true state=0
2018-03-23 09:01:50: ClientService cmd: PONG
2018-03-23 09:01:55: ClientService cmd: STATUS#pw=YPiq<...>1ukk
2018-03-23 09:02:14: ClientService cmd: STATUS DETAIL#pw=YPiq<...>1ukk
2018-03-23 09:03:31: rc=0 hasError=true state=0
Server:
2018-03-23 09:01:03: ERROR: Constructing of filelist of "Quboid" failed: error - prefilebackup script failed with error code 1
2018-03-23 09:01:12: ERROR: Backup had an early error. Deleting partial backup.
2018-03-23 09:01:13: WARNING: Exponential backoff: Waiting at least 2h 40m before next file backup
