Fresh install, Dattobd failed to mount XFS in LVM
We have a fresh machine (tried on two separate instances), with AlmaLinux9, Dattobd. The sistem has XFS filesystems on LVM.
Fstab:
/dev/mapper/almalinux-root /                       xfs     defaults        0 0
UUID=eb5bb418-904e-4e57-b536-931c9194db56 /boot                   xfs     defaults        0 0
/dev/mapper/almalinux-swap none                    swap    defaults        0 0
/dev/data/mail	/var/vmail	xfs	defaults,inode64        0 0
Urbackup client log:
2024-03-20 12:42:54: ERROR: Creating snapshot of "/etc" failed
2024-03-20 12:42:54: ERROR: Snapshotting device /dev/mapper/almalinux-root via dattobd...
2024-03-20 12:42:54: ERROR: Using /dev/datto1...
2024-03-20 12:42:54: ERROR: CBT=type=datto&reset=1
2024-03-20 12:42:54: ERROR: Mounting /dev/mapper/wsnap-6323d02f9b2f8d3da61b5b371b3837353711408b3a9a5d13...
2024-03-20 12:42:54: ERROR: mount: /mnt/urbackup_snaps/6323d02f9b2f8d3da61b5b371b3837353711408b3a9a5d13: wrong fs type, bad option, bad superblock on /dev/mapper/wsnap-6323d02f9b2f8d3da61b5b371b3837353711408b3a9a5d13, missing codepage or helper program, or other error.
2024-03-20 12:42:54: ERROR: Mounting filesystem failed
2024-03-20 12:42:54: ERROR: Creating snapshot of "etc" failed.
2024-03-20 12:43:04: ERROR: Snapshotting device /dev/mapper/almalinux-root via dattobd...
2024-03-20 12:43:04: ERROR: Using /dev/datto2...
2024-03-20 12:43:04: ERROR: CBT=type=datto&reset=1
2024-03-20 12:43:04: ERROR: Mounting /dev/mapper/wsnap-5103cc0ae9e8d3733e166a50bbd3d3cabc649f53267d2af4...
2024-03-20 12:43:04: ERROR: mount: /mnt/urbackup_snaps/5103cc0ae9e8d3733e166a50bbd3d3cabc649f53267d2af4: wrong fs type, bad option, bad superblock on /dev/mapper/wsnap-5103cc0ae9e8d3733e166a50bbd3d3cabc649f53267d2af4, missing codepage or helper program, or other error.
2024-03-20 12:43:04: ERROR: Mounting filesystem failed
2024-03-20 12:43:14: ERROR: Snapshotting device /dev/mapper/almalinux-root via dattobd...
2024-03-20 12:43:14: ERROR: Using /dev/datto2...
2024-03-20 12:43:14: ERROR: CBT=type=datto&reset=1
2024-03-20 12:43:14: ERROR: Mounting /dev/mapper/wsnap-a4608c6e4dd22a157433a49decaeaea26017efd76fa1feb9...
2024-03-20 12:43:14: ERROR: mount: /mnt/urbackup_snaps/a4608c6e4dd22a157433a49decaeaea26017efd76fa1feb9: wrong fs type, bad option, bad superblock on /dev/mapper/wsnap-a4608c6e4dd22a157433a49decaeaea26017efd76fa1feb9, missing codepage or helper program, or other error.
2024-03-20 12:43:14: ERROR: Mounting filesystem failed
2024-03-20 12:43:23: ERROR: Creating snapshot of "/usr/lib/os-release" failed
2024-03-20 12:43:23: ERROR: Snapshotting device /dev/mapper/almalinux-root via dattobd...
2024-03-20 12:43:23: ERROR: Using /dev/datto2...
2024-03-20 12:43:23: ERROR: CBT=type=datto&reset=1
2024-03-20 12:43:23: ERROR: Mounting /dev/mapper/wsnap-15f50c18b959c19a4d21b991cfb16a85f2a7bcd24dfd7f79...
2024-03-20 12:43:23: ERROR: mount: /mnt/urbackup_snaps/15f50c18b959c19a4d21b991cfb16a85f2a7bcd24dfd7f79: wrong fs type, bad option, bad superblock on /dev/mapper/wsnap-15f50c18b959c19a4d21b991cfb16a85f2a7bcd24dfd7f79, missing codepage or helper program, or other error.
2024-03-20 12:43:23: ERROR: Mounting filesystem failed
DMESG:
[Wed Mar 20 12:42:43 2024] loop: module loaded
[Wed Mar 20 12:42:43 2024] loop0: detected capacity change from 0 to 204800
[Wed Mar 20 12:42:43 2024] XFS (dm-3): Mounting V5 Filesystem
[Wed Mar 20 12:42:43 2024] XFS (dm-3): Starting recovery (logdev: internal)
[Wed Mar 20 12:42:43 2024] XFS (dm-3): Ending recovery (logdev: internal)
[Wed Mar 20 12:42:52 2024] loop1: detected capacity change from 0 to 204800
[Wed Mar 20 12:42:52 2024] XFS (dm-4): Mounting V5 Filesystem
[Wed Mar 20 12:42:53 2024] XFS (dm-4): Corruption warning: Metadata has LSN (3:95282) ahead of current LSN (3:95265). Please unmount and run xfs_repair (>= v4.3) to resolve.
[Wed Mar 20 12:42:53 2024] XFS (dm-4): log mount/recovery failed: error -22
[Wed Mar 20 12:42:53 2024] XFS (dm-4): log mount failed
[Wed Mar 20 12:42:53 2024] dm-4: detected capacity change from 58286080 to 0
[Wed Mar 20 12:42:53 2024] datto: error unlinking file: -1
[Wed Mar 20 12:42:53 2024] loop1: detected capacity change from 0 to 204800
[Wed Mar 20 12:42:54 2024] XFS (dm-4): Mounting V5 Filesystem
[Wed Mar 20 12:42:54 2024] XFS (dm-4): Starting recovery (logdev: internal)
[Wed Mar 20 12:42:54 2024] XFS (dm-4): Ending recovery (logdev: internal)
[Wed Mar 20 12:43:03 2024] loop2: detected capacity change from 0 to 204800
[Wed Mar 20 12:43:03 2024] XFS (dm-5): Mounting V5 Filesystem
[Wed Mar 20 12:43:03 2024] XFS (dm-5): Corruption warning: Metadata has LSN (3:95539) ahead of current LSN (3:95525). Please unmount and run xfs_repair (>= v4.3) to resolve.
[Wed Mar 20 12:43:03 2024] XFS (dm-5): log mount/recovery failed: error -22
[Wed Mar 20 12:43:03 2024] XFS (dm-5): log mount failed
[Wed Mar 20 12:43:03 2024] dm-5: detected capacity change from 58286080 to 0
[Wed Mar 20 12:43:04 2024] datto: error unlinking file: -1
[Wed Mar 20 12:43:13 2024] loop2: detected capacity change from 0 to 204800
[Wed Mar 20 12:43:13 2024] XFS (dm-5): Mounting V5 Filesystem
[Wed Mar 20 12:43:13 2024] XFS (dm-5): Corruption warning: Metadata has LSN (3:95633) ahead of current LSN (3:95631). Please unmount and run xfs_repair (>= v4.3) to resolve.
[Wed Mar 20 12:43:13 2024] XFS (dm-5): log mount/recovery failed: error -22
[Wed Mar 20 12:43:13 2024] XFS (dm-5): log mount failed
[Wed Mar 20 12:43:13 2024] dm-5: detected capacity change from 58286080 to 0
[Wed Mar 20 12:43:13 2024] datto: error unlinking file: -1
[Wed Mar 20 12:43:22 2024] loop2: detected capacity change from 0 to 204800
[Wed Mar 20 12:43:22 2024] XFS (dm-5): Mounting V5 Filesystem
[Wed Mar 20 12:43:22 2024] XFS (dm-5): Corruption warning: Metadata has LSN (3:95707) ahead of current LSN (3:95693). Please unmount and run xfs_repair (>= v4.3) to resolve.
[Wed Mar 20 12:43:22 2024] XFS (dm-5): log mount/recovery failed: error -22
[Wed Mar 20 12:43:22 2024] XFS (dm-5): log mount failed
[Wed Mar 20 12:43:23 2024] dm-5: detected capacity change from 58286080 to 0
[Wed Mar 20 12:43:23 2024] datto: error unlinking file: -1
[Wed Mar 20 12:43:32 2024] loop2: detected capacity change from 0 to 204800
[Wed Mar 20 12:43:32 2024] XFS (dm-5): Mounting V5 Filesystem
[Wed Mar 20 12:43:32 2024] XFS (dm-5): Starting recovery (logdev: internal)
[Wed Mar 20 12:43:32 2024] XFS (dm-5): Ending recovery (logdev: internal)
[Wed Mar 20 12:43:34 2024] XFS (dm-3): Unmounting Filesystem
[Wed Mar 20 12:43:34 2024] dm-3: detected capacity change from 67100672 to 0
[Wed Mar 20 12:43:35 2024] XFS (dm-4): Unmounting Filesystem
[Wed Mar 20 12:43:35 2024] dm-4: detected capacity change from 2097152 to 0
[Wed Mar 20 12:43:41 2024] XFS (dm-5): Unmounting Filesystem
[Wed Mar 20 12:43:41 2024] dm-5: detected capacity change from 58286080 to 0
Somehow the next full backup finished with NO errors. So sometimes it works, sometimes it doesn’t.
First incremental:
2024-03-20 13:02:39: ERROR: Creating snapshot of "/etc" failed
2024-03-20 13:02:39: ERROR: Snapshotting device /dev/mapper/almalinux-root via dattobd...
2024-03-20 13:02:39: ERROR: Trying to transition /dev/datto2 to snapshot...
2024-03-20 13:02:39: ERROR: dbdctl transition-to-snapshot /datto_3d41c58e-6724-4d47-8981-11c766a08a24_a2480e8e7295ce86b980f8a634bf2a01dbe6354c2aa78c52 2
2024-03-20 13:02:39: ERROR: Transitioned /dev/datto2 to snapshot.
2024-03-20 13:02:39: ERROR: CBT_FILE=/.datto_3d41c58e-6724-4d47-8981-11c766a08a24_c8a1e01631f20cffbe2fd3a53f5e48db8524a68597600f4f
2024-03-20 13:02:39: ERROR: CBT=type=datto
2024-03-20 13:02:39: ERROR: Mounting /dev/mapper/wsnap-a2480e8e7295ce86b980f8a634bf2a01dbe6354c2aa78c52...
2024-03-20 13:02:39: ERROR: mount: /mnt/urbackup_snaps/a2480e8e7295ce86b980f8a634bf2a01dbe6354c2aa78c52: wrong fs type, bad option, bad superblock on /dev/mapper/wsnap-a2480e8e7295ce86b980f8a634bf2a01dbe6354c2aa78c52, missing codepage or helper program, or other error.
2024-03-20 13:02:39: ERROR: Mounting filesystem failed
2024-03-20 13:02:39: ERROR: Creating snapshot of "etc" failed.
DMESG:
[Wed Mar 20 13:02:23 2024] loop0: detected capacity change from 0 to 204800
[Wed Mar 20 13:02:23 2024] XFS (dm-3): Mounting V5 Filesystem
[Wed Mar 20 13:02:23 2024] XFS (dm-3): Starting recovery (logdev: internal)
[Wed Mar 20 13:02:23 2024] XFS (dm-3): Ending recovery (logdev: internal)
[Wed Mar 20 13:02:37 2024] loop1: detected capacity change from 0 to 204800
[Wed Mar 20 13:02:38 2024] XFS (dm-4): Mounting V5 Filesystem
[Wed Mar 20 13:02:38 2024] XFS (dm-4): Corruption warning: Metadata has LSN (3:97389) ahead of current LSN (3:97379). Please unmount and run xfs_repair (>= v4.3) to resolve.
[Wed Mar 20 13:02:38 2024] XFS (dm-4): log mount/recovery failed: error -22
[Wed Mar 20 13:02:38 2024] XFS (dm-4): log mount failed
[Wed Mar 20 13:02:38 2024] dm-4: detected capacity change from 58286080 to 0
[Wed Mar 20 13:02:38 2024] datto: error unlinking file: -1
[Wed Mar 20 13:02:39 2024] loop1: detected capacity change from 0 to 204800
[Wed Mar 20 13:02:39 2024] XFS (dm-4): Mounting V5 Filesystem
[Wed Mar 20 13:02:39 2024] XFS (dm-4): Starting recovery (logdev: internal)
[Wed Mar 20 13:02:39 2024] XFS (dm-4): Ending recovery (logdev: internal)
[Wed Mar 20 13:02:40 2024] datto: device specified does not exist: -2
[Wed Mar 20 13:02:40 2024] datto: error during transition to snapshot ioctl handler: -2
[Wed Mar 20 13:02:48 2024] loop2: detected capacity change from 0 to 204800
[Wed Mar 20 13:02:48 2024] XFS (dm-5): Mounting V5 Filesystem
[Wed Mar 20 13:02:48 2024] XFS (dm-5): Starting recovery (logdev: internal)
[Wed Mar 20 13:02:48 2024] XFS (dm-5): Ending recovery (logdev: internal)
[Wed Mar 20 13:02:50 2024] XFS (dm-3): Unmounting Filesystem
[Wed Mar 20 13:02:50 2024] dm-3: detected capacity change from 67100672 to 0
[Wed Mar 20 13:02:50 2024] XFS (dm-4): Unmounting Filesystem
[Wed Mar 20 13:02:50 2024] dm-4: detected capacity change from 2097152 to 0
[Wed Mar 20 13:02:56 2024] XFS (dm-5): Unmounting Filesystem
[Wed Mar 20 13:02:56 2024] dm-5: detected capacity change from 58286080 to 0
Next incremental sometimes work, but mostly not.
Also it created 10 (obviously ran it 10 times) “.datto_…” files with the size of 3GB (probably 10% of 32BG disk) in /, but didn’t delete it, so disk got full very fast.
Urbackup was quite stable on CentOS 7, never used is on any other system. But this is very unstable.
I can assist with testing, but I have no idea what to do next.
Thank you for your help!
This is coming at me too. I have a Hyper-V Ubuntu setup with LVM/XFS two disks, and both snapshots cannot be mounted for same reason.
Is this connected to datto? Or the original xfs filesystem has something hidden? The ubuntu system works as expected.
Seriously, no developer checked this problem? This is happening on all freshly installed systems with LVM/XFS with DATTOBD. How is this not a priority?
Sadly, I’m already looking for alternative software like urbackup.
Greetings
this isn’t specific to xfs, happens with ext4 also.
Also notice that the .datto or shadow files grow really fast while snapshot is active.
I’m wondering if it’s related to the .swap file standard on ubuntu?
