How long does it usually take to get the updates to all the different install locations?
I see the server reporting new version available but 2.3.7 is all that installs with
pkg update
pkg install urbackup-server
is 2.3.7
pkg update
is 2.3.7
Hi, I don’t know much about FreeNAS, but I’m running UrBackup on FreeBSD servers - any chance they are using the same repo? If so then it is probably that problem with latest vs quaterly branch.
have a look into iocage jail ports.
There you can find 2.3.8 now
sorry i forgot to mention … sometimes it helps changing pkg quarterly branch to latest with
nano /etc/pkg/FreeBSD.conf
and changing the line
url: “pkg+http://pkg.FreeBSD.org/${ABI}/quarterly”
to
url: “pkg+http://pkg.FreeBSD.org/${ABI}/latest”
and
pkg update
i would do this only in jails and not in the freenas system
but as far as i know the latest urbackup-server version is found in ports
