server 2.1.19
Whenever attempting to do a raw COW image backup, I receive 1 of two errors on all windows machines…
“Backing up System Reserved (SYSVOL) partition failed. Image backup failed”
or
“Error creating file for writing MBR data. Permission denied (code: 13)”
normal VHD and file backups work fine
ALL_NONUSB set
urbackup:urbackup has ownership -R of /tank and /usr/local/var/urbackup
echo “tank/images” > /etc/urbackup/dataset
echo “/tank/urbackup” > /etc/urbackup/backupfolder
urbackup_snapshot_helper tests OK and folders get created in /tank/images for the backups
where else should I check for permissions? Thanks.
